Problem with metadata
Permanent link to this post Posted by Piteur » Mon Jan 16, 2017 1:41 pm
Bonjour.
Utilisant Audacity 2.1.2 sous Xubuntu 16.04 LTS, chaque fois que je valide de nouveaux metadata, je reçois un message d'erreur :
Le fichier d'erreur qu'on peut sauvegarder contient les données suivantes :
Code: Select all
ASSERT INFO:
../src/common/wincmn.cpp(478): assert "GetEventHandler() == this" failed in ~wxWindowBase(): any pushed event handlers must have been removed
BACKTRACE:
[1] wxWindowBase::~wxWindowBase()
[2] wxWindow::~wxWindow()
[3] wxControlBase::~wxControlBase()
[4] wxChoiceBase::~wxChoiceBase()
[5] wxChoice::~wxChoice()
[6] wxComboBox::~wxComboBox()
[7] wxComboBox::~wxComboBox()
[8] wxWindowBase::Destroy()
[9] wxWindowBase::DestroyChildren()
[10] wxWindow::~wxWindow()
[11] wxWindowBase::Destroy()
[12] wxWindowBase::DestroyChildren()
[13] wxWindow::~wxWindow()
[14] wxGrid::~wxGrid()
[15] Grid::~Grid()
[16] TagsEditor::~TagsEditor()
[17] Tags::ShowEditDialog(wxWindow*, wxString, bool)
[18] AudacityProject::OnEditMetadata()
[19] CommandManager::HandleCommandEntry(CommandListEntry const*, unsigned int, unsigned int, wxEvent const*)
[20] CommandManager::HandleMenuID(int, unsigned int, unsigned int)
[21] AudacityProject::OnMenu(wxCommandEvent&)
[22] wxAppConsoleBase::HandleEvent(wxEvtHandler*, void (wxEvtHandler::*)(wxEvent&), wxEvent&) const
[23] wxAppConsoleBase::CallEventHandler(wxEvtHandler*, wxEventFunctor&, wxEvent&) const
[24] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[25] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[26] wxEvtHandler::TryHereOnly(wxEvent&)
[27] wxEvtHandler::ProcessEventLocally(wxEvent&)
[28] wxEvtHandler::ProcessEvent(wxEvent&)
[29] wxWindowBase::TryAfter(wxEvent&)
[30] wxEvtHandler::ProcessEvent(wxEvent&)
[31] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[32] wxWindowBase::HandleWindowEvent(wxEvent&) const
[33] wxMenuBase::SendEvent(int, int)
[34] g_cclosure_marshal_VOID__VOID
[35] g_closure_invoke
[36] g_signal_emit_valist
[37] g_signal_emit
[38] gtk_widget_activate
[39] gtk_menu_shell_activate_item
[40] g_closure_invoke
[41] g_signal_emit_valist
[42] g_signal_emit
[43] gtk_propagate_event
[44] gtk_main_do_event
[45] g_main_context_dispatch
[46] g_main_loop_run
[47] gtk_main
[48] wxGUIEventLoop::DoRun()
[49] wxEventLoopBase::Run()
[50] wxAppConsoleBase::MainLoop()
[51] wxAppConsoleBase::OnRun()
[52] wxAppBase::OnRun()
[53] wxEntry(int&, wchar_t**)
[54] wxEntry(int&, char**)
[55] main
[56] __libc_start_main
[57] _start
Comment éviter ce bug, qui ne gêne pas le fonctionnement, toutefois ?
Merci
-------------- EDIT ---------------
Le problème semble connu et résolu dans la prochaine version d'Audacity : viewtopic.php?f=48&t=94435
Hello.
Using Audacity 2.1.2 under Xubuntu 16.04 LTS, whenever I validate new metadata, I get an error message:
The error file (backtrace) that can be saved contains the following data:
Code: Select all
ASSERT INFO:
BACKTRACE:
[15] Grid::~Grid()
[37] g_signal_emit
[42] g_signal_emit
[47] gtk_main
[55] main
[57] _start
How to avoid this bug, which doesn't block operation, however?
Thank you
--------------- EDIT -------------------
The problem seems to be known and resolved in the next version of Audacity: viewtopic.php?f=48&t=94435
Piteur
Re: Problem with metadata
Permanent link to this post Posted by steve » Mon Jan 16, 2017 1:55 pm
This bug has been fixed in the development code and the fix will be in the next Audacity release (2.1.3).
You 'may' be able to work around this bug by clicking on one of the tag names (in the left hand column) before you close the Metadata Editor.
Permanent link to this post Posted by Piteur » Mon Jan 16, 2017 2:08 pm
Many thanks, Steve. Perfect!
Piteur
Return to Français
Who is online
Users browsing this forum: No registered users and 2 guests
