Bug: Audacity 2.3.0 crashes on second entry to Manage Macros
Bug reports for Audacity 2.3.0 alpha
This forum is only for feedback and bug reports for the specified version of Audacity.
All bug reports must include the following information:
  • Exact version number of Audacity
  • Operating system version
  • Brief description of the problem
  • Detailed, step by step instructions for how to reproduce the problem
Bug reports that do not include the above information will be deleted
Additional information and / or screenshots should be included as necessary to adequately describe the problem.
Permanent link to this post Posted by StuartGauffi » Wed Mar 21, 2018 12:40 pm
Windows 10 Home, Version 1709, Build 16299.309
Audacity 2.3.0 alpha, build 20180320-91, 20180321-92
- Click Tools | Macros
- Choose macro that includes EQ, Normalize, Export to MP3
- Click Files...
- Select multiple files
- Click OK
- Click Save, OK for each file
- Click Cancel in Manage Macros window
Audacity Crashes
StuartGauffi
Re: Bug: Audacity 2.3.0 crashes on second entry to Manage Ma
Permanent link to this post Posted by steve » Wed Mar 21, 2018 12:55 pm
Thanks for the report.
A crash has previously been reported on Mac and Windows when the macro includes "Export to MP3".
Could you test if the crash still occurs if:
  • You remove the "Export to MP3" step
  • If you replace "Export to MP3" with some other export
  • If you remove or replace the other effects from the macro to determine if the export step is the problem.
Permanent link to this post Posted by StuartGauffi » Sun Mar 25, 2018 3:50 pm
Here are results of the requested tests:
Export to OGG instead of MP3
- Same crash
Remove Export step
- Equalize, Normalize
- Same crash
Remove Normalize step
- Equalize only
- Same crash
Replace Equalize with Normalize
- Normalize only
- Same crash
StuartGauffi
Permanent link to this post Posted by waxcylinder » Sun Mar 25, 2018 5:13 pm
I think this has alraedy been fixed the the developer who is working on Macros
See: https://github.com/audacity/audacity/co ... b4eaa96c76
waxcylinder
Permanent link to this post Posted by StuartGauffi » Mon Mar 26, 2018 9:39 pm
Confirmed: bug fixed; Build 96 works without crashing.
StuartGauffi
Permanent link to this post Posted by waxcylinder » Tue Mar 27, 2018 9:58 am
StuartGauffi wrote:Confirmed: bug fixed; Build 96 works without crashing.
Thanks for reporting back Stuart - much appreciated.
Just be aware that the transition to Macros is still very much a work-in-progress - there are still a few" wrinkles" we have to iron out ...
See this Wiki page: https://wiki.audacityteam.org/wiki/Macr ... ssion_page
Peter.
waxcylinder
Return to Audacity 2.3.0 alpha bug reports
Who is online
