Radio
Radio
Permanent link to this post Posted by Johnb2 » Sun Dec 10, 2017 11:12 pm
Hi Lads,
I have been recording the volunteer audiobooks with Audacity and I am using 2.2.1. I also follow the audiobook mastering process which works quite well, thank you.
Recently a friend asked if I could record a few spots for him to run on the radio. However, the last time I did one it was on an Ampex reel to reel. I am wondering if I can do it with Audacity and how different need the process be from the audiobook mastering. When I would record freelance stuff at local studios in the 70's they used to compress the heck out of the audio to make it jump out of the speakers, can I do that myself in Audacity? Any tips and tricks?
john
Johnb2
Re: Radio
Permanent link to this post Posted by Trebor » Mon Dec 11, 2017 12:45 am
Johnb2 wrote:When I would record freelance stuff at local studios in the 70's they used to compress the heck out of the audio to make it jump out of the speakers, can I do that myself in Audacity? Any tips and tricks?
The new & improved "LevelSpeech2.ny" plugin will do that ...
''LevelSpeech2'' suggested settings.png (8.08 KiB) Viewed 551 times
How to install plugin ...http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#install
Trebor
Re: Radio
Permanent link to this post Posted by Johnb2 » Mon Dec 11, 2017 2:28 am
Thanks Trebor.
I downloaded it. Looks good! Is it the final part of your chain or do you normalize after it?
john
Johnb2
Re: Radio
Permanent link to this post Posted by Trebor » Mon Dec 11, 2017 10:32 am
Johnb2 wrote: Is it the final part of your chain or do you normalize after it?
Sometimes LevelSpeech2 can be a little bit too loud & cause clipping. Normalizing afterwards will cure that ...
Normalize used to cure clipping caused by ''Levelspeech2''.gif (75.34 KiB) Viewed 536 times
[ Red lines are "show clipping" ]
Trebor
Re: Radio
Permanent link to this post Posted by Johnb2 » Mon Dec 11, 2017 1:22 pm
Thanks again, Trebor
Johnb2
Re: Radio
Permanent link to this post Posted by kozikowski » Mon Dec 11, 2017 7:44 pm
The link says "Experimental Version. When is it real?
Are the revisions called out in the code? Which Rev is current?
Re: Radio
Permanent link to this post Posted by Trebor » Tue Dec 12, 2017 1:05 am
kozikowski wrote:The link says "Experimental Version. When is it real?
The experiment was to add sliders for attack & decay times.
Once they have been adjusted to match speech they could be hidden.
The original (nonadjustable) attack & decay times on LevelSpeech were too slow for speech, IMO.
Trebor
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
