Select the Whole Track
Permanent link to this post Posted by kozikowski » Mon Nov 20, 2017 3:03 pm
What's the party line for selecting the whole track? You can't click just above MUTE any more. It doesn't exist in 2.2.0. Double click the track waves? They're not blue any more, either.
Re: Select the Whole Track
Permanent link to this post Posted by steve » Mon Nov 20, 2017 3:32 pm
I generally click here, but I'm not sure what a good way to describe that is.
It's not a big target, but it is always visible, even if the track is collapsed.
Also note that double clicking on the waveform selects the "audio clip". If there is just one audio clip in the track, then that's the same as selecting the track, but not if the track contains multiple audio clips.
Permanent link to this post Posted by waxcylinder » Mon Nov 20, 2017 4:41 pm
Or you can double-click in the track's waveform.
waxcylinder
Permanent link to this post Posted by kozikowski » Mon Nov 20, 2017 7:45 pm
It's worse than that. If you Shift-Click inside the waves, it forms a segmented selection. You don't get "this wave and that wave."
Yes, I wouldn't have any trouble writing a paragraph on that. "You see that little blank spot on the bottom of the track INFO panel just to the right .............."
Permanent link to this post Posted by steve » Mon Nov 20, 2017 7:50 pm
kozikowski wrote:It's worse than that. If you Shift-Click inside the waves, it forms a segmented selection
What is a "segmented selection"?
Permanent link to this post Posted by kozikowski » Mon Nov 20, 2017 8:05 pm
Might his be an actual program change/update?
Double click the Circle? Double click the Dot? There isn't a lot of room for graphic craziness.
Target. A two-element target symbol.
I can do this in Illustrator. Photoshop is a stretch.
I guess the good news is it's only a graphic change. The action is already desirable.
Permanent link to this post Posted by kozikowski » Mon Nov 20, 2017 8:09 pm
Wave double click > Shift other wave double click will do this:
Screen Shot 2017-11-20 at 12.07.37.png (31 KiB) Viewed 224 times
Permanent link to this post Posted by kozikowski » Mon Nov 20, 2017 8:23 pm
Double click the zebra stripes.
Permanent link to this post Posted by steve » Mon Nov 20, 2017 8:57 pm
kozikowski wrote:Double click the Circle? Double click the Dot? There isn't a lot of room for graphic craziness.
Less than you think - that space is already used when Sync-Lock is enabled. But when Sync-Lock is enabled you can say "Click on the clock in the track info box".
Is this a hypothetical problem, or do you think that we really need another way to select the entire contents of a track?
Permanent link to this post Posted by waxcylinder » Mon Nov 20, 2017 11:04 pm
steve wrote:Is this a hypothetical problem, or do you think that we really need another way to select the entire contents of a track?
How about a double-click on the track name - or an additional entry in the TCP dropdown menu for "Select Track" :?:
Or both even ...
Peter.
waxcylinder
Next
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 3 guests
