What are the best over ear headphones
Permanent link to this post Posted by Jackxxx » Sun Jul 09, 2017 5:09 pm
What are the best over ear headphones for editing audiobook recordings?
I currently have Audio-technical ATH M30
Thank you,
Jackxxx
Re: What are the best over ear headphones
Permanent link to this post Posted by steve » Sun Jul 09, 2017 5:13 pm
There's no such thing as "best", but "comfort" is essential.
The ATH M30's should be quite well suited to the job, if you find them comfortable.
Permanent link to this post Posted by kozikowski » Sun Jul 09, 2017 6:00 pm
Pay attention to the ACX reports (if that's your vendor). If you get rejected for something you can't hear, then that's a problem.
"Can't you hear that rumble in the background?"
Ummmm. No.
There's a split between goals. "The Hollywood" headphone is the Sony MDR 7506. Virtually all movie shoots have at least one and usually several. Besides the mechanical tricks (fully articulated pads), they will reveal sound problems usually before anybody else hears them. That's very different from enjoying a movie for two hours. I can't listen to 7506s for extended periods and several sound people can't either.
There's another problem that has little or nothing to do with headphones. Nobody hears noise. The first time you play back a voice work, you discover that rattly sound your refrigerator makes and (in my case) I can hear take-offs and landings at LAX. Your head tunes out noises like that until they get stuck on a recording.
One poster discovered he needed to present late at night so as not to get traffic noises from his neighborhood.
Quality of voice, unless your microphone is broken or you're using it wrong, is way down the list.
It's more of an adventure than you think.
Permanent link to this post Posted by Mack Caster » Mon Jul 10, 2017 3:52 pm
Jackxxx wrote:What are the best over ear headphones for editing audiobook recordings?
Thank you,
The ATH M30 is great for what you are doing. They are well priced and although you could spend hundreds more, you would gain very little doing so. One of the most overlooked item with using headphones for editing is making sure that you do not have any sound effects activated during playback via your soundcard. If your system/sound card does have this feature, make sure you select "none" as the default action.
Mack Caster
Banned
Permanent link to this post Posted by kozikowski » Mon Jul 10, 2017 5:16 pm
Totally.
I once got a machine to evaluate that had "Cathedral Effects" running by accident. It failed every sound test "for some reason."
Permanent link to this post Posted by jhighland171 » Fri Aug 11, 2017 5:39 pm
My favorites are the ATH-M50x headphones. They're great for editing on Audacity or just listening to music for fun.
jhighland171
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
