ACX requests all files replaced of at least 192 bit rate.
Permanent link to this post Posted by Ted R Brown » Wed Mar 22, 2017 8:12 pm
Equipment:
Audio Software: Audacity 2.1.2
Audio Interface: Scarlett 2i2 2nd Gen
High Pass Filter: Shure A14HP
Mic: Blue Spark
Here are my settings.
Every file saved to WAV
Project Rate = 44100
WAV exported to MP3
Format: Quality = Standard, 170-210 kbps; Variable speed: Fast
I do have the Interface Meter dB range: -72 dB (PCM range of 12 bit samples)
Does audacity have anything that shows the bit rate of a file?
Should I change the Format to: Extreme, 220-260 kbps?
Speed: Fast? Standard?
How do I make the Track Name appear on the Track Label?
Thanks
Ted
Ted R Brown
Re: ACX requests all files replaced of at least 192 bit rate
Permanent link to this post Posted by steve » Wed Mar 22, 2017 9:25 pm
Select "Constant" as the bit-rate mode, then 192 kbps as the "Quality".
Unless you have a really good reason not to, your recordings should be mono.
Permanent link to this post Posted by Ted R Brown » Wed Mar 22, 2017 9:44 pm
The recording channel shows MONO. When exporting to MP3, Channel Mode does not offer MONO as a choice. There is a radio button that requires a choice of "Joint Stereo" or "Stereo".
I will have to go back and from the WAV file save a NEW MP3 file. Correct? How do I make the Track Name appear on the Track Label?
Thanks Steve!
Ted
Ted R Brown
Permanent link to this post Posted by steve » Wed Mar 22, 2017 9:50 pm
Ted R Brown wrote:The recording channel shows MONO.
Good. The MP3 will also be mono. Those "stereo mode" settings only apply if the project is stereo.
Ted R Brown wrote:I will have to go back and from the WAV file save a NEW MP3 file. Correct?
Yes, either the WAV file or the original Audacity project, but do NOT re-encode the MP3 as that will needlessly reduce the sound quality.
Ted R Brown wrote:How do I make the Track Name appear on the Track Label
I've no idea what you mean.
Return to Audiobook Production
Who is online
