RMS Normalizing
RMS Normalizing
Permanent link to this post Posted by steve » Mon Dec 21, 2015 10:29 am
There is a new "RMS Normalize" plug-in available that may be useful to people engaged in producing audiobooks.
It is available here: viewtopic.php?p=293878#p293878
Re: RMS Normalizing
Permanent link to this post Posted by Gembo85 » Wed Feb 17, 2016 3:22 am
Hi Steve- thankyou for this.
Without any fiddling, I'm at an RMS of -31.1 dB and peak amplitude of -6.6453. I need to adjust this to fit the ACX perameters of between -18 and -23 and peak -3.
Can I simply use the RMS normaliser to within the spectrum (say -20) and then hard limit the peaks to - 3?
I suspect its much more complicated than that....?
Gembo85
Re: RMS Normalizing
Permanent link to this post Posted by Gembo85 » Wed Feb 17, 2016 3:45 am
Sorry- forgot to attach a clip for your reference- any help on this would be greatly appreciated...
Gembo85 wrote:Hi Steve- thankyou for this.
EXAMPLECLIPCN.wav
Example
(1.27 MiB) Downloaded 83 times
Gembo85
Re: RMS Normalizing
Permanent link to this post Posted by steve » Wed Feb 17, 2016 1:26 pm
Your recording level is a little low. That means that you will need to amplify the recording, and that will raise the noise level as well as the signal.
A good level to aim for in your recording is for a maximum peak level of about -6 dB. That gives you a waveform of about half the height of the track when in the default "Waveform" view.
Have you tried just amplifying/normalizing that audio clip to a peak level of -3 dB (as required by ACX) and measuring the RMS level? Try it. I get an RMS of -21.5 dB, which sits close to the middle of the specified (-18 to -23 dB) range, and there are no massive peaks that stand out as being much higher than the rest. In other words, no compression or limiting required.
Re: RMS Normalizing
Permanent link to this post Posted by Gembo85 » Wed Feb 17, 2016 2:38 pm
Cheers for getting back to me Steve, really appreciate it- The actual track is 30 minutes long so I think there's a couple of discrepancies that are altering with the values.
Yup, my first port of call was to amplify to -3db peak and the RMS worked out at 27.4. Here is a screen shot of the full waveform after amplifying to -3db peak. I'm going to need to compress first right? Because there's a couple of odd peaks? Or am I best off Isolating those peaks and reducing their amplification before raising the whole thing? It's been a year since I last did this and I'm rusty I'm afraid!
Gembo85
Re: RMS Normalizing
Permanent link to this post Posted by steve » Wed Feb 17, 2016 3:32 pm
Could you post a short sample at about the 12:30 mark. I see there is a big spike there.
Also, when you make a screenshot for the forum, please reduce the size of the Audacity window first so that the image fits better in the forum page - it saves a lot of scrolling for those trying to read your post and view the image.
Re: RMS Normalizing
Permanent link to this post Posted by Gembo85 » Wed Feb 17, 2016 4:00 pm
Thanks Steve- this is the spike with the amplify to -3b.
1230clip.wav
(163.1 KiB) Downloaded 69 times
Gembo85
Re: RMS Normalizing
Permanent link to this post Posted by steve » Wed Feb 17, 2016 4:48 pm
Taking a somewhat 'unscientific' approach, I've roughly drawn by eye a line showing a kind of "average peak level" of your recording as a whole.
I notice that there's a period of a few minutes where the peaks get higher and higher, then lower again until it finally settles down at about 15:00 back to a similar level as the first 10 minutes. I'm not able to tell from the images 'why' that is - perhaps you were becoming enthralled in the drama, which is a good thing from a 'performance' point of view, but not so good from a recording point of view.
Before you do anything, ensure that you have a good backup copy in WAV format, preferably "32-bit float WAV".
I'd suggest that you try a bit of compression to even out that rise in volume.
It's difficult to judge the settings from just a short sample, but as a starting point I'd suggest something like this:
I'd advise not going much above 4:1 for the compression ratio, and keep the attack time at a couple of seconds or more. The control to twiddle with is the "Threshold".
You will need to normalize to -3 dB after using the compressor.
Re: RMS Normalizing
Permanent link to this post Posted by Zetrick » Fri Nov 17, 2017 9:33 am
I know this topic is quite old, but I was wondering if there is a way to use this RMS-Normalize function in a chain? I'd would like to batch process multiple files with it, and having to open each file and run it can take a long time...
Thanks!
Zetrick
Re: RMS Normalizing
Permanent link to this post Posted by steve » Fri Nov 17, 2017 1:08 pm
Zetrick wrote:I know this topic is quite old, but I was wondering if there is a way to use this RMS-Normalize function in a chain?
Yes, once the plug-in has been installed it can be used in a Chain.
Next
Return to Audiobook Production
Who is online
Users browsing this forum: No registered users and 2 guests
