Hi Forum,
As most of the beginners coming here I could really use some help with my recordings. I am trying to start recording reading short stories and post them on YT. The important part is that it is not going to be signing – just me reading text, maybe adding some comments at the beginning and end. I have tried to master my vocal as good as I can but I have this feeling that I am doing it all wrong. Part of it is probably working with my own voice makes me feel weird. However, I am not so sure about the plugins and setting I am using. At the moment I am using following settings, this is data raw from the chain I am trying to do:
Normalize: ApplyGain=yes RemoveDcOffset=yes Level=-1.000000 StereoIndependent=no
Compressor: Threshold=-15.000000 NoiseFloor=-40.000000 Ratio=2.500000 AttackTime=0.300000 DecayTime=1.000000 Normalize=no UsePeak=no
Bass and Treble: Bass=3.000000 Treble=8.000000 Level=1.000000 Normalize=no
NoiseGate: funct=Gate stlink=“Link Stereo Tracks” hpf=No freq=0.000000 level-red=-12.000000 thresh=-35.200000 attack=250.000000
So basically, I normalize to -1, then compress, add bass and treble (+3 and +8), than normalize to -1 again, run NoiseGate with at -35db to get rid of any possible background sounds left in there and export. I have tried to manually equalize the track but I have failed miserably so I am using ‘bass and treble boost’ plugin. I have also included before and after sound tests. This is just a headlines from BBC News so please ignore the subject - this was the only one not talking about war or economy. Also, I am not a native English speaker so please ignore the accent.
My goal is simple – get good crisp sound without sounding weird and unnatural. I do understand that I am not a professional announcer and do not have particularly good voice. Also recordings are done in my bedroom with USB microphone which might also be an issue. I use Audio Technica AT2020USB+. I have tried to upload .wav files but they were over 1MB. I have files in MP3 will be good enought.
Thanks for your help.
Horzy
