Help with tracks for a hypnosis audio
I’m making a relaxation hypnosis audio, and want to be able to do two things
  1. split tracks, meaning a separate track for each ear, running at the same time. I know it will sound confusing, but it works well in hypnosis.
  2. Is there a way to make one such track go from ear to the other? A single mono track, that starts in the left ear and then kind of swoops over to the right and maybe back again? Sorry for the high-tech jargon! :laughing:
Thanks so much!
Create a stereo track of the basic show. Then, using the drop-down menus on the left, Split Stereo Track.
After that, you can apply the Envelope Tool (two white arrows and bent blue line) to each track individually.
http://manual.audacityteam.org/o/man/tools_toolbar.html
When you get the affect you want, use the same drop-down menu and Make Stereo Track. Export as normal.
Thank you so much! I appreciate your help
As if the sound source was rotating around your head ? , there’s a plugin for that, see … Binaural spin effect
