URGENT!! 3 MICS on MIXER & I need to Isolate Each Track
Audacity Podcaster Forum.
Permanent link to this post Posted by havfun3009 » Thu Oct 05, 2017 5:18 pm
I'm doing a podcast with Boy Meets World Producer--
We have 3 MICS on a MIXER and we need to Isolate Each Track.
Currently we are able to get 1 mic on its own track & the other 2 mics seem to be on one track. Is there a way to do this?
PLEASE HELP!
havfun3009
Re: URGENT!! 3 MICS on MIXER & I need to Isolate Each Track
Permanent link to this post Posted by kozikowski » Thu Oct 05, 2017 7:13 pm
No. Audacity will accept multi-track mixer/interfaces (4-track) for recording, but you don't have a multi-track mixer—that we can tell.
If you're all in the same non-studio room, you will have zero chance to isolate each voice from the others anyway. So your only chance to pull this off is manually mix the show on good headphones while it's going. If you've never done that before, it will be a challenge.
If you want to beat this up more, we'll need the mixer maker and model number and who made the microphones. You're not in a studio or quiet room, are you?
Also remember the forum elves are sprayed across nine time zones and not all of us are into live recording.
Permanent link to this post Posted by havfun3009 » Thu Oct 05, 2017 10:20 pm
Really Appreciate your time to respond to my message! That is correct--- we have a BEHRINGER XENYX X1204USB mixer and the microphones are--Audio Technica ATR2100-USB USB/XLR Microphone
We are not in a studio or quiet room--that is correct!
havfun3009
Permanent link to this post Posted by steve » Fri Oct 06, 2017 12:12 am
If I recall correctly, the BEHRINGER XENYX X1204USB can only record 2 audio channels (stereo).
Audacity can only record from one device at a time, so with the equipment you have described, you will only be able to record a maximum of 2 independent audio channels.
To record more the 2 channels, you would need to use a sound card with more input channels. Unfortunately we don't know which multi-channel sound cards work with Audacity - some don't because they require ASIO for multi-channel recording, and Audacity does not support ASIO.
Another option would be to record on a hardware multi-channel recorder (example: Boss BR-800, or Zoom R-16).
Permanent link to this post Posted by kozikowski » Fri Oct 06, 2017 3:45 am
That doesn't mean you can't force the mixer into giving you three independent voices. You can. This mixer has two "sends." The red and orange knobs.
So. Leave them down on microphones one and two. Fade those normally so one is Left and the other Right. Feed those out to the computer for recording normally. For Microphone three, you leave the slide fader down, but turn up, say FX Send (the orange knob). FX Send has a master on the right of the console. Turn that up, too. Plug the second recorder into AUX Send 2-FX on the top row of connectors.
It will be a juggling act to start and stop the recorders and as near as I can tell, FX Send has no volume meters, so you'll need to use the ones on the second recorder.
Are you following all this?
Sound Sync is going to be a really big deal, so just after you start both recorders and before they start performing, yell "SOUND SYNC! and clap your hands once. That sets the sync mark much like the movie people do.
Screen Shot 2017-10-05 at 20.37.54.png (30.96 KiB) Viewed 307 times
Now you know what the movie clap board does.
It will be insanely handy to do that at the end, too, but nobody is going to remember to do that.
Yes it does work. I've done that on a complicated shoot.
You can record Mic 3 with with a second computer by adding a behringer UCA-202 or equivalent. That's an analog to USB converter. Plugging directly into the computer MIC-IN is not recommended.
I've done that, too.
Permanent link to this post Posted by kozikowski » Fri Oct 06, 2017 4:31 am
I don't mean to suggest you're out of the woods even if you get all that to work. Each microphone is going to capture one performer's good voice and the bare-wall echo of the other two. Any correction you make to one voice is going to affect the echo of the others.
And if you do use the second computer technique for the third microphone, sound sync is super important because if you don't get that right, the show will have two sets of "wrong voice" echoes, not one and it may get worse as the show progresses.
You picked a very serious show for your maiden voyage.
Return to Podcasting with Audacity
Who is online
Users browsing this forum: No registered users and 3 guests
