Sound quality is garbage
Audacity Podcaster Forum.
Re: Sound quality is garbage
Permanent link to this post Posted by Enlightenedoutdoors » Sun Aug 13, 2017 1:37 am
here is the first test recording
mme and yeti selected all windows settings are turned off and enhancements turned off as recommend
testing microphone.aup
recording with windows setting changed and all enhancments turned off and levels to 100 percent. NME with yeti on both settings
(1.42 KiB) Downloaded 9 times
Enlightenedoutdoors
Permanent link to this post Posted by Enlightenedoutdoors » Sun Aug 13, 2017 1:40 am
this is the same test except changing the setting to wasapi and playing with the gains and volume on audacity a little
testing 2.aup
windows wasapi setting
Enlightenedoutdoors
Permanent link to this post Posted by Enlightenedoutdoors » Sun Aug 13, 2017 1:41 am
this is windows direct setting played with the gains a little
testinfg 3.aup
changed to windows direct
(1.41 KiB) Downloaded 10 times
Enlightenedoutdoors
Permanent link to this post Posted by kozikowski » Sun Aug 13, 2017 3:07 am
Thanks for all the work, but an AUP isn't a sound file. It's an Audacity Project manager text file.
There's a 2MB limit on stuff the forum will let you post. So post mono and if you're in WAV, that will allow super high quality 20 seconds. You can use good quality mono MP3 (128 quality or higher) and just keep going until the size reaches 2MB.
Permanent link to this post Posted by kozikowski » Sun Aug 13, 2017 3:14 am
I wrote a thing on posting a sound sample, but you may be beyond simple posting rules. Yetis can have background noise problems, so do include a second or two of hold-your-breath silence.
http://www.kozco.com/tech/audacity/Test ... _Clip.html
Permanent link to this post Posted by Enlightenedoutdoors » Mon Aug 14, 2017 10:37 pm
is there a rule of thumb on recording settings like mme, wasapi, diresct etc!!
I did a couple of test recordings after restarting my system and it sounded alot better it may actually be good.
thank you for all your help so far
Enlightenedoutdoors
Permanent link to this post Posted by kozikowski » Mon Aug 14, 2017 11:43 pm
A word on restarting. If you start having serious problems, cold restart with Shift-Shutdown. It takes longer and Windows closes and resets more things. Regular restart is the quickie convenience that may give you a warm feeling, but doesn't reset everything.
Previous
Return to Podcasting with Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
