Audacity Plugins for Podcasters
Audacity Podcaster Forum.
Permanent link to this post Posted by ChBBur » Tue Mar 07, 2017 4:09 pm
Quick Question - I'm coming back to podcasting after a 2-year hiatus and wanted to know if there are any recommendations for Audacity plugins and/or addons outside of LAME. I previously used a compressor addon. However, I have read that isnt recommended. Any recommendations would be greatly appreciated.
Thanks,
Chris
ChBBur
Re: Audacity Plugins for Podcasters
Permanent link to this post Posted by kozikowski » Tue Mar 07, 2017 11:55 pm
That's just too fuzzy/open-ended.
What's the show? What's the goal? Are you gamecasting? Skype interviews?
Assuming your basic recording is without obvious errors (P-Popping, Hissss noises), I would be tempted to use Chris's Compressor. Chris can take whatever you did and even it out so there are no wild volume changes over the course of your show. He designed it so he could listen to opera in the car. So that's the metaphor. Listen without constantly turning the volume up and down.
I use it on a download/podcast show to simulate the broadcast version. The podcast is missing the broadcast compressors and limiters, so listening to the podcast during hiking or long, romantic walks on the beach is painful without some help.
Permanent link to this post Posted by kozikowski » Wed Mar 08, 2017 9:44 pm
Missed a step there.
https://theaudacitytopodcast.com/chriss ... -audacity/
For my use, a stiff compression, I change the first value, Compress ratio from default 0.5 to 0.77. The density and evenness goes up and it's an almost perfect copy of the local NPR station compression.
Permanent link to this post Posted by kozikowski » Thu Mar 09, 2017 11:14 pm
I'm taking you at your word that you're doing an actual podcast. The AudioBook people have a very different set of rules.
Return to Podcasting with Audacity
Who is online
