I apologize for getting the letters mixed up with the EBU Steve and I have went back and corrected my mistakes. I am dyslexic and it seems the older I get, the more I have to really pay attention to my writing.
I have shown you via links to the EBU website where they do allow for different setting for the mobile players and Podcasting. Here again, their suggestions, not mine. Even the Auphonic website states this as well. Their program was designed to meet the EBU suggestions and they even have the terms “Mobil and Podcasting” built into their program, under their desired LUFS target.
It is also on the desk top version of their software, that they sell to the public. You can view the picture below, I have paid for their program so I could use it off line and I use it weekly. It is no different then the ACX Analyzer that comes with Audacity. They both are simple to use and both take the mathematics out of the equation.
When I made two request on the forum about the Podcasting LUFS requirement and adding cover art, you were the first to respond.
https://forum.audacityteam.org/t/adding-cover-art-meeting-i-85-compliant-needs/41419/1
Dana: “Is there anyway to add cover art using Audacity?
Steve: “No, not yet. MP3Tag is a good alternative. This is a popular request, though we don’t currently have any developers working on it. It is logged on the Audacity wiki feature request page and I have added your vote“.
Even Koz suggested adding it as a new tool with Audacity. “New tool: I-85 Check
Koz” on the same page as mentioned above.
Then we started going back and forth Steve over the -16 and -19 LUFS for Podcasting. I provided you with links to show / back my position on this subject. I do this so others will know that I AM NOT giving my opinion, rather basing it on the people that write the suggestions for others to follow.
Now on this page, http://forum.audacityteam.org/viewtopic.php?f=20&t=89982&start=10
You made the following comment: “It might be interesting to see what the ReplayGain level is after processing with "Auphonic Leveler"on the Podcast setting. I’d guess that you will get fairly consistent results, in which case you could use the “ReplayGain” plug-in that I linked to in my previous post.
At some point I would like to make a general “loudness normalizing” plug-in for Audacity that supports multiple standards, including RMS (various weightings), ReplayGain, EBU-R128, ITU BS.1770-3, EBU Tech 3342 and others. Unfortunately Nyquist plug-ins currently have problems normalizing very long tracks, and since this plug-in would be quite a lot of work, I’ve been deferring it until that limitation is resolved“.
Now, to answer your question above Steve, after I run my audio through Auphonic at a -19LUFS for mono, Audacity says it need a “0.3db increase” after I analyze it using the “Replay Gain Analyzer“. Since I have no knowledge of writing code, I have no idea what that means but I am sure that you will. If you need any samples from me, set at different LUFS, just let me know and I will try to provide you, with what you need. Please just be as specific as you can.
On page http://forum.audacityteam.org/viewtopic.php?f=20&t=89982&start=10, of the forum, you make the following statement of:
“Steve: OK, so I can see that several podcasting sites recommend a level of -16 LUFS“.
So you are aware of this and I provided you with links to the EBU where they do in fact allow for application other then the -23LUFS. Yet you still want to push this issue with me. The issue is not with me Steve, your issue lies with the EBU guidelines, not mine.
So now you say: “I am aware that you are not “signed up” to the support crew, but you are putting yourself in the role of teaching other Audacity users, and with that comes responsibility for accuracy and clarity. I do not want to cause you embarrassment, so I would be happy to move this topic off the public forum if that is your wish“.
Any information I have provided on this forum, is 100% verifiable, via outside resources. When I state my opinion, I make sure that I include that fact, in my posts and replies. Now one of the member posted this, directed at me:
“Dana, I’ve watched the video - thanks for that. A lot of it was just reinforcement of what I’ve already started coming to understand. I want to keep my process as simple as yours is. That’s what I’m aiming for. Maybe I’m close to that already“.
Now on page https://forum.audacityteam.org/t/file-conversion-editing-and-fidelity/215/1 I made the following statement concerning the ACX requirements. “Your noise floor peaks @ a -57dbs, which has already failed ACX requirements, before you even start recording. I will explain in the picture below. I also made you a five min vid, showing you how to check your system. I would love for someone with more experience then myself, concerning the ACX, to check my line of thinking. I have no desire to give out false information“.
Since no one corrected me on the information concerning the 5 min video, I will assume my advice to this member, is correct. Now, I have no idea how to sign up for the “support crew” but if you provide with the link, I will check it out and see if it is something I may be able to do or if this community will even except me.
As far as saving me embarrassment and you moving the post out of the public forum, if you choose to do so, it will be due to saving yourself embarrassment on a subject, you seem to have very little knowledge in when it comes to Podcasting. Even though it is a subject, that is so clear to anyone else in the Podcasting Field, that comes straight from the mouth of the EBU, allowing these modifications.
