Panning does not work
For Musicians to Share Their Music, Tips, Tricks and Reviews.
Permanent link to this post Posted by firepat » Mon Dec 25, 2017 10:14 pm
Even if I pan with the volume slider, it doesnt work..... music stays in the middle...
If I assign 1 mono track to the left channel, it's still in the middle!
need help on that
Patrick
firepat
Operating System: Windows 7
Re: Panning does not work
Permanent link to this post Posted by kozikowski » Wed Dec 27, 2017 1:29 am
Describe your sound system. Does it do that when you plug in headphones?
Permanent link to this post Posted by kozikowski » Wed Dec 27, 2017 1:32 am
Do the playback (speaker icon) sound meters shift back and forth?
Screen Shot 2017-12-26 at 17.31.15.png (7.03 KiB) Viewed 239 times
Permanent link to this post Posted by Trebor » Wed Dec 27, 2017 1:47 am
kozikowski wrote:Do the playback (speaker icon) sound meters shift back and forth?
Like this ...
panning demo.gif (1 MiB) Viewed 238 times
Trebor
Permanent link to this post Posted by flynwill » Wed Dec 27, 2017 3:37 pm
If you are running windows run the built-in channel test:
(These instructions are for Windows 10, other versions are similar but a bit different):
Open "Control Panel".
Select "Hardware and Sound"
Select "Manage Audio Devices" under "Sound"
Right-click your "speakers" (or whatever your selected audio devices is) and choose "test"
This will produce mi re do from the left speaker followed by do re me from left.
flynwill
Operating System: GNU/Linux other
Permanent link to this post Posted by kozikowski » Thu Dec 28, 2017 4:46 am
And might also give you one from the right.
@firepat
Any of that help? It's fairly standard troubleshooting to split the system in sections and see if all the sections work by themselves. Then connect them little at a time and see where normal operation falls apart.
If you're a new user, this can seem a little overly complex, but you wouldn't need to worry about any of this if your system just worked. Having a problem puts you in troubleshooting mode and unfortunately, that happens on line with several different elves across multiple time zones.
Let's see. If it's 9PM here that means it's ... 5AM in Manchester??
Return to Making Music with Audacity
Who is online
