I could not split stereo to mono
For Musicians to Share Their Music, Tips, Tricks and Reviews.
Permanent link to this post Posted by asiye.yigit » Sun Dec 03, 2017 8:53 am
Hi;
I have tried all suggestions to make a karaoke from the song in youtube. However, I could not.
https://www.youtube.com/watch?v=5fTxjt3yH2o&list=RD5fTxjt3yH2o#t=0
For instance, you can check the above link. It can not be. please tell me waht my mistake is.
best regards;
Asiye Yigit
asiye.yigit
Re: I could not split stereo to mono
Permanent link to this post Posted by Trebor » Sun Dec 03, 2017 11:29 am
asiye.yigit wrote:I have tried all suggestions to make a karaoke from the song in youtube. However, I could not.
https://www.youtube.com/watch?v=5fTxjt3 ... t3yH2o#t=0
Only sometimes possible to remove vocal in Audacity: it depends on the recording.
The stereo reverberation effect which has been applied to the voice makes removing it via Audacity impossible in this case.
Trebor
Permanent link to this post Posted by steve » Sun Dec 03, 2017 11:30 am
Vocal reduction effects assume that the vocal is a centre panned mono sound - in other words, that part of the audio signal that is the vocal, is identical in both left and right channels. That would normally be the case if you made a stereo recording of someone singing with a band, without applying any effects to the vocal.
The example track that you posted has a huge amount of "stereo reverb" effect applied to the vocal, so the vocal in the left channel is not the same as the vocal in the right channel. Because there is hardly any commonality between the vocal in the left channel and the vocal in the right channel, it is not possible to make automatic removal of the vocal. The vocal reduction / removal effects will fail with that audio.
Return to Making Music with Audacity
Who is online
Users browsing this forum: No registered users and 3 guests
