USB CONDENSER MIC
For Musicians to Share Their Music, Tips, Tricks and Reviews.
USB CONDENSER MIC
Permanent link to this post Posted by pennyroyaltea94 » Tue Nov 21, 2017 4:05 pm
So I am thinking of getting the USB one , So I COULD perhaps skip the need of getting PHANTOM POWER ,
Anyone here work with USB Verisons ? It's just mean't for STUDIO VOCAL RECORDINGS , Myself :mrgreen:
pennyroyaltea94
Re: USB CONDENSER MIC
Permanent link to this post Posted by pennyroyaltea94 » Tue Nov 21, 2017 4:21 pm
Only reason I am thinking of doing this idea is because , it would make the process of doing vocals tracks feel less like a production , meaning the focus and spirit isn't too disturbed/distracted.
pennyroyaltea94
Permanent link to this post Posted by kozikowski » Tue Nov 21, 2017 7:52 pm
We have one note about microphones that have driver software. If you have Windows 10, it is required that you have Windows 10 driver software with the microphone or device. Windows 10 is not a simple Windows upgrade and older software may not work or be stable. It's a whole new world and takes dedicated software.
How were you planning on running the analog microphone version if you didn't get the USB model?
That and it's not that unusual for some microphones to have noise trouble with some computers. It's not always plug-and-play.
USB microphones have one invisible problem. It's usually a bad idea to have a noisy computer in the same room while you're recording. USB microphones can never get more than one USB cable (roughly 6 feet - 2M) away from the computer.
You are the poster child for hiring a small studio.
Permanent link to this post Posted by pennyroyaltea94 » Wed Nov 22, 2017 1:00 am
kozikowski wrote:We have one note about microphones that have driver software. If you have Windows 10, it is required that you have Windows 10 driver software with the microphone or device. Windows 10 is not a simple Windows upgrade and older software may not work or be stable. It's a whole new world and takes dedicated software.
lol and yeah I think I'll just get the NON USB , Just get a phantom power box too , No need to get USB and then it won't work with WINDOWS 10
pennyroyaltea94
Permanent link to this post Posted by kozikowski » Wed Nov 22, 2017 4:01 am
Describe the rest of the setup. If you have a small sound mixer, it's very likely to have 48 volt phantom power built-in. There is only one small mixer I know of that claims in big text that it has "Phantom Power!!" but in tiny letters near the bottom, admits to the older 12 volt instead of 48 volt.
The single passive cable that adapts your analog microphone to your computer Mic-In connection is Very Highly Not recommended. Those things can create weird sound quality issues and magic, time-bomb problems.
"I don't know either. One of the three clients claims very low volume and distorted sound. They want us to submit the work again...???"
I'm very nearly not making that up.
You can get a small but nice microphone USB adapter with built-in 48 volt phantom power. I have a Behringer UM2 interface. That's the black thing on the left. It has zero latency monitoring so you can plug headphones in and do perfect musical overdubbing.
That is a condenser microphone that takes 48 volts and a Mac laptop that makes little or no noise.
They also make a fancier UMC22.
https://www.sweetwater.com/store/detail/UMC22
Permanent link to this post Posted by pennyroyaltea94 » Wed Nov 22, 2017 4:31 pm
I bought Lexicon Alpha it doesn't have PHANTOM POWER , but it's real awesome , I got it dirt cheap used.
I wanted to get all HARMAN Stuff , like AKG and Lexicon :D
I just simply need to get a PHANTOM BOX for the Mic , that doesn't bother me .
pennyroyaltea94
Permanent link to this post Posted by kozikowski » Wed Nov 22, 2017 6:38 pm
Appears you’re good to go.
Permanent link to this post Posted by pennyroyaltea94 » Thu Nov 23, 2017 12:35 am
kozikowski wrote:Appears you’re good to go.
Cool thanks , yeah I was at 1st thinking getting a USB Verison but I am not going to take a chance of it not working too well with WINDOWS 1O or Future Windows.
So yes I am getting My AKG CONDENSER and then 1 of thoses BEHRINGER PHANTOM BOXES , Their suppose to be good and they are $25.
pennyroyaltea94
Permanent link to this post Posted by kozikowski » Thu Nov 23, 2017 1:12 am
That would be this?
https://www.sweetwater.com/store/detail/PS400
That should do it.
Do you have a tripod or other mic stand?
Apparently it comes with a desk stand?
Three items:
-- It didn't say so, but apparently, it doesn't have a filter for desk vibrations. That's not deadly. If you find yourself recording furnace noises from the basement or metrobus noises through the floor, you can get rid of them with the Book and Towel method.
-- Depending on your desk or table, it's good to cover it over underneath the microphone to prevent odd comb filtering effects and slap sounds. See in that same picture, the microphone isn't sitting on the table, it's sitting on a blue furniture moving blanket. That's not accidental.
-- In fuzzy general, you should be about a Hawaiian Shaka away from the microphone when you perform.
How were you planning on getting your face that close to the microphone? You can do that with enough books and towels, but I like the boom mike stand.
That's a Clorox bleach bottle with water in it. 8.3 pounds per gallon. I don't need the books and towels because I use a vibration and shock mount at the microphone. That's what that spider-y thing in back of the mic is. The boom gives you room underneath the mic to play, sing or read the script.
And if you find you like your sound closer yet to the microphone, you'll need the pop and blast filter.
That's the black tennis racket thing. This is what it sounds like if you do that wrong.
http://kozco.com/tech/audacity/clips/PPopping.mp3
Directional microphones have proximity effect. The sound gets richer and deeper the closer you get, but you do have to be careful.
Permanent link to this post Posted by pennyroyaltea94 » Thu Nov 23, 2017 1:46 am
Yup that PHANTOM BOX from Sweetwater is what I am getting.
Yup got plently of stands ,
I from the beginning wasn't to far off from having the proper set up,
Always been taking A SHOT IN THE DARK doing this :lol:
this is the type of filter I am rolling with , Ordered it.
s-l1600 (1).jpg (93.36 KiB) Viewed 199 times
pennyroyaltea94
Next
Return to Making Music with Audacity
Who is online
