Can you make all pitches uniform?
Hi, I’ve never used this program, but I’ve heard it’s good. I was wondering if there’s a simple way to take a song or any audio file and change all the pitches throughout it so that there is just one constant pitch. I’m interested in simulating the experience of someone with amusia. Thanks!
I’m going with no. I’m guessing by the long hang time on the forum, nobody else knows, either.
Thanks for your advice :wink:
It might be possible with auto-tune (a commercial product). I’m sure the side-effects would get pretty horrible however.
Can you tell us a little bit more?
Do you want just a simple sine wave with the amplitude of the original or how should I understand this?
