Export
For Teachers and Educators.
Using Audacity in the Classroom.
Export
Permanent link to this post Posted by student » Thu Aug 06, 2015 1:26 pm
Is it possible export data about time of amplitudes to Excel(texteditor....)?
student
Re: Export
Permanent link to this post Posted by Gale Andrews » Thu Aug 06, 2015 1:37 pm
Re: Sample Data Export
Permanent link to this post Posted by student » Mon Aug 17, 2015 9:08 am
Where can i change the time of interval between each sample?
i need step about 1 (or 0,5) sec but i can't found it
student
Re: Export
Permanent link to this post Posted by steve » Mon Aug 17, 2015 9:40 am
"Sample Data Export" exports sequential samples. It is a "Nyquist" plug-in (http://wiki.audacityteam.org/wiki/Nyqui ... _Reference) so it is possible for users to modify it.
What exactly are you trying to do?
Re: Export
Permanent link to this post Posted by student » Mon Aug 17, 2015 9:57 am
the best will be something like this:
time: volume:
[hh:mm:ss] [dB]
00:00:03 65
00:00:21 45
00:00:53 72
00:01:13 53
Snímek obrazovky 2015-08-17 v 11.50.24.png (31.3 KiB) Viewed 1582 times
student
Re: Export
Permanent link to this post Posted by student » Mon Aug 17, 2015 10:03 am
and if is not possible this... so i need this one:
time volume
00:00:00 55
00:00:01 63
00:00:02 ...
00:00:03 ...
00:00:04 ...
01:30:23 ...
student
Re: Export
Permanent link to this post Posted by steve » Mon Aug 17, 2015 10:08 am
I think I see what you mean.
It would be quite easy to make the plug-in output every n'th sample (example, every 100th sample), but that's probably not going to give you what you want, unless the peaks are evenly spaced at intervals of a known number of samples.
What Sample Data Export is designed to do, is to output the raw data (sample values) in a simple text / csv format so that the data can be analyzed in other application (such as spreadsheets or graph drawing programs). What are you wanting to do with the data? What is the purpose of this?
Re: Export
Permanent link to this post Posted by student » Mon Aug 17, 2015 10:57 am
ok...can you send me some instruction, how can i get the data with n-th simples?
maybe that would be ok only with this data :) its for some project in school and i must compare results from another attempt :)
student
Re: Export
Permanent link to this post Posted by steve » Mon Aug 17, 2015 11:47 am
You've not said what you are doing with the data. Do you really need to modify the plug-in? Why not just ignore all of the values that you don't need?
Re: Export
Permanent link to this post Posted by student » Mon Aug 17, 2015 2:01 pm
cause i need work with record which has about 2 hours ...if sample data write about sounds each 0.00002 sec that wouldn't be good (the best for me will be every 0.5 or 1 sec)
student
Next
Return to Audacity in Education
Who is online
Users browsing this forum: No registered users and 2 guests
