Trying to convert an MP3 to an AU file.
For help using Audacity, please post in the Help forum relevant to your operating system.
If you require help using Audacity, please post on the forum board relevant to your operating system.
Permanent link to this post Posted by louis345 » Tue Jun 19, 2012 7:02 pm
It looks like Audacity has released a newer version of this program. All the tutorials I have seen deal with the older version.
My computer is windows 7.0 and I have an mp3 file that i need to switch it to AU 8 bit version for my Java program. I think my question is pretty straightforward and easy to answer. Hopefully, I can get a response quickly, so I can finish my wonderful Java program.
thanks in Advance.
louis345
Re: Trying to convert an MP3 to an AU file.
Permanent link to this post Posted by kozikowski » Tue Jun 19, 2012 7:50 pm
http://manual.audacityteam.org/help/manual/
You can greatly increase the number and type of files that Audacity will export by installing the FFMpeg software.
http://audacity.sourceforge.net/download/
Permanent link to this post Posted by Trebor » Tue Jun 19, 2012 8:59 pm
NB: there are different types of 8-bit AU format files ... https://en.wikipedia.org/wiki/Au_file_format
Trebor
Permanent link to this post Posted by louis345 » Tue Jun 19, 2012 9:43 pm
I still don't see how to convert from mp3 to au. Thanks.
louis345
Permanent link to this post Posted by Trebor » Tue Jun 19, 2012 10:18 pm
louis345 wrote:I still don't see how to convert from mp3 to au.
As Kozikowski was saying, you have to install a thing called FFmpeg into Audacity to maximize the number of formats it can read and write, instructions how to do that are here ...
http://manual.audacityteam.org/help/manual/man/faq_installation_and_plug_ins.html#ffdown
You do need to identify which type of 8-bit AU file your application needs.
In Audacity export, AU format is in "options" of "other uncompressed files".
AU is in 'options' for 'other uncompressed files'.png (31 KiB) Viewed 918 times
8-bit pcm AU test.zip
AU test file in Zip file. an 8-bit pcm AU file made in Audacity from an mp3
(272.36 KiB) Downloaded 37 times
Trebor
Return to All Things Audio
Who is online
Users browsing this forum: No registered users and 3 guests
