How to restore old style veritical zoom?
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by Tapehead » Fri Mar 23, 2018 12:26 am
I stayed with 2.1.2 because I didn't like some of the later gui 'improvements', but i thought I'd give it another
whirl and discovered a new vertical zoom right click context menu.
I don't care for it either.
Is this hardwired or can I change it back?
Tapehead
Re: How to restore old style veritical zoom?
Permanent link to this post Posted by steve » Fri Mar 23, 2018 8:56 am
Permanent link to this post Posted by Tapehead » Fri Mar 23, 2018 10:36 pm
Still getting the new vertical scrolling context menu on right click popping up. Sometimes it behaves in classic fashion but mostly not.
Plus there is the added irritant of when I reduce the zoom in increments and don't realise I'm all the way there... and make an extra click the pesky context menu pops up again.
Win7 - with latest Audacity zip download
Tapehead
Permanent link to this post Posted by billw58 » Fri Mar 23, 2018 11:09 pm
Right-click now brings up the context menu. To zoom out use shift-click.
I sympathize. I preferred right-click for zoom out since I didn't have to add a modifier key. At least shift-right-click still does a zoom-reset.
-- Bill
billw58
Permanent link to this post Posted by waxcylinder » Sat Mar 24, 2018 10:40 am
To use the old-style Vertical Zoom just use the left-click in the Vertical Ruler
As explained earlier this is now off by default (lots of folk were getting confused by it and stuck) so you need to turn on Advanced Vertical Zooming in Preferences as explained above in a earlier post in this thread.
If you don't like/want the context menu then just don't right-click in the vertical ruler (there is no opetion/preference to turn the right-click context menu off).
But even if you are an advanced left-clicker zoomer - there is one really useful command for you in the right-click context menu and that is Zoom Reset which returns you to normal (default) vertical zoom level.
waxcylinder
Permanent link to this post Posted by Tapehead » Sat Mar 24, 2018 4:27 pm
Thanks Bill, I have always disliked using modifiers and have adapted my most used Audacity shortcuts to avoid them.
WC & Steve, thanks but I had already checked the advanced option before posting my query, but thought I'd missed something because of the way it functions
Therefore I'm staying with 2.1.2
Tapehead
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 2 guests
