Filetree recognition in Export dialog
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by jimmyhosen » Tue Dec 19, 2017 10:24 am
Hello, I experienced a significant problem due to Audacity 2.2.1 failing to check the current filetree structure during export. Instead, Audacity forced the re-creation of a deprecated filetree structure of folders on my PC and put the exported file into the end folder.
Please change Audacity to stop doing this. Instead, please make Audacity check the current filetree structure. If the structure does not match the last-used filepath, then please make Audacity go to the highest level that matches the last-used filepath.
Thank you for considering this.
Here is a link to my case-study:
Operating System: Windows 7
Return to Audacity 2.x Feedback and Reviews
Who is online
