Bug: can't add user-defined images using .xpm
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by jik » Tue Aug 15, 2017 5:03 pm
There is a bug in overloaded function RegisterImage(iIndex, pXpm, Name). This function is used if we want to add user-defined image using .xpm file. The Mask is not set. As a result, initAlpha() clears the image. SetMaskColour() should be added before initAlpha():
Code: Select all
void ThemeBase::RegisterImage( int &iIndex, char const ** pXpm, const wxString & Name ) {
   wxASSERT( iIndex == -1 ); // Don't initialise same bitmap twice!
   wxImage Img(pXpm);
   Img.SetMaskColour(0xDE, 0xDE, 0xDE); // <-- missed call
   Img.InitAlpha();
   RegisterImage( iIndex, Img, Name );
jik
Operating System: Windows 7
Re: Bug: can't add user-defined images using .xpm
Permanent link to this post Posted by steve » Tue Aug 15, 2017 5:16 pm
Which version are you looking at? That does not appear to quite match the current code: https://github.com/audacity/audacity/bl ... /Theme.cpp
Permanent link to this post Posted by jik » Tue Aug 15, 2017 5:24 pm
line 457 by your github link:
Code: Select all
   wxBitmap Bmp( pXpm ); // a 24 bit bitmap.
   wxImage Img( Bmp.ConvertToImage() );
   Img.InitAlpha();
jik
Permanent link to this post Posted by steve » Tue Aug 15, 2017 5:41 pm
I'm not familiar with this part of the code, so all I can do is pass this on to the developer's mailing list, or you can do that yourself if you prefer.
Permanent link to this post Posted by jik » Tue Aug 15, 2017 5:58 pm
Function wxImage::InitAlpha() check the Mask. If there is no Mask it just clears the image:
Code: Select all
    if ( HasMask() )
    else // no mask
        // make the image fully opaque
        memset(alpha, wxIMAGE_ALPHA_OPAQUE, lenAlpha);
Could you please pass the report on the developer's mailing list?
jik
Permanent link to this post Posted by steve » Tue Aug 15, 2017 6:04 pm
jik wrote:Could you please pass the report on the developer's mailing list?
Sure, will do. Thanks.
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 3 guests
