Changing Times [SOLVED]
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by Groove » Thu Jul 13, 2017 10:05 am
I have been using Audacity for a while to record my songs. I use backtracks and then sing live. Today when exporting the audacity project files to MP3 status the times have all doubled up . Example song saved in Audacity shows times of 3min43 but once I export to MP3 it shows times as 7m24. Can anyone tell what has changed so I can correct.
Groove
Operating System: Windows XP
Re: Changing Times
Permanent link to this post Posted by Gale Andrews » Thu Jul 13, 2017 10:14 am
Check the player you are using that claims double time. Perhaps it does not support variable bit rate, in which case export from Audacity as Constant Bit Rate.
Re: Changing Times [SOLVED]
Permanent link to this post Posted by Groove » Thu Jul 13, 2017 10:49 am
Thank you . Sorted
Groove
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 6 guests
