Hi again,
I have two almost identical tracks but they are in different projects each with varying start and end points in the timeline. I've messed up a section of one and want to crossfade in/out a section from the other.
However the intros & outros of both tracks are fade-ups/fade outs from slightly different points so I can't just slide the second track along until the yellow line appears and I can't zoom right in and do a bit of math from the timeline values to synch them either.
I've been manually trying to line them up by progessively zooming in and sliding the second track waveform but I just ain't getting it spot on. I can hear slight phasing.
Are there other methods or a plugin that can sync identical parts of two waveforms automatically?
