how to cut mp3
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
how to cut mp3
Permanent link to this post Posted by hijazen » Sat Oct 27, 2012 8:40 pm
I want to cut the first 7 seconds of a song (the song should start from the 7th second) but do not know how, can anybody help me?
thanks
hijazen
Re: how to cut mp3
Permanent link to this post Posted by kozikowski » Sat Oct 27, 2012 10:02 pm
Step one should probably be to not use Audacity. Audacity doesn't directly edit MP3 and you can cause sound damage by simple editing like you want to do.
Use MP3Splt or one of the other direct MP3 editors. These can directly cut your song but they have a very simple tool set.
http://mp3splt.sourceforge.net/mp3splt_page/home.php
Re: how to cut mp3
Permanent link to this post Posted by steve » Sun Oct 28, 2012 1:01 pm
If you don't mind a little loss in sound quality you can edit an MP3 in the same way as any other audio file.
File menu > Import > Audio (to import the MP3 into Audacity)
Select the part that you want to delete: http://manual.audacityteam.org/o/man/au ... ction.html
Press the Del key to delete it.
File menu > Export (to export the edited audio as a new file)
See also: http://manual.audacityteam.org/o/man/tu ... _file.html
Re: how to cut mp3
Permanent link to this post Posted by fyzyc » Fri May 19, 2017 12:00 pm
If you do not want to download the software, WebAudioCutter can do it easily. It's free and online.
Reason: hot link removed
fyzyc
Re: how to cut mp3
Permanent link to this post Posted by steve » Fri May 19, 2017 12:32 pm
fyzyc wrote:If you do not want to download the software
As this is the Audacity forum, I think that we can assume that forum users already have Audacity.
If the user wants to trim the MP3 with no sound quality loss, then they need to use an MP3 editor that can trim without re-encoding, which your on-line app does not do.
Please also note that we do not allow advertising on this forum.
Return to Audacity 2.x Feedback and Reviews
Who is online
Users browsing this forum: No registered users and 4 guests
