Are all the dropouts detected from Jack, PA, WASAPI?
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by Kdmeizk » Thu Mar 15, 2018 4:03 pm
Hello,
Are all the dropouts detected when the sound comes from:
  • [UNIX] Jack → Audacity
  • [UNIX] PulseAudio → Audacity
  • [Windows] WASAPI (loopback) → Audacity
Kdmeizk
Operating System: Windows 7
Re: Are all the dropouts detected from Jack, PA, WASAPI?
Permanent link to this post Posted by steve » Fri Mar 16, 2018 10:19 am
No, Audacity can't detect "upstream" dropouts, only "downstream".
Permanent link to this post Posted by Kdmeizk » Fri Mar 16, 2018 1:11 pm
Ok. So if Jack produces a dropout, Audacity cannot know it, only Jack can know it, right?
Kdmeizk
Permanent link to this post Posted by steve » Fri Mar 16, 2018 2:42 pm
I did some tests, and that appears to be the case.
If you use QJackCtl to configure and start Jack, it will show xruns that occur on its side of Audacity.
Permanent link to this post Posted by Kdmeizk » Fri Mar 16, 2018 6:50 pm
I do not really understand. An xrun is shown in QjackCtl, and Audacity knows an xrun happened in QjackCtl? But you said Audacity cannot detect “upstream” dropouts?
In general, Jack/PulseAudio/WASAPI (= what I understood as your word “upstream”), Audacity really does not know if they produce a dropout, right?
Kdmeizk
Permanent link to this post Posted by steve » Sat Mar 17, 2018 7:23 pm
Kdmeizk wrote:An xrun is shown in QjackCtl, and Audacity knows an xrun happened in QjackCtl?
No, Audacity does not know that.
I was trying to say that Audacity 2.2.2 can detect "downstream" dropouts (missed writes to disk), and if you use QjackCtl, then QjackCtl will show "upstream" dropouts (xruns detected by Jack).
Permanent link to this post Posted by Kdmeizk » Sat Mar 17, 2018 9:55 pm
steve wrote:Audacity 2.2.2 can detect "downstream" dropouts (missed writes to disk)
Because they are reported to Audacity (thanks to errors I assume)?
Kdmeizk
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 3 guests
