Exporting files [SOLVED]
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by Chaz » Sun Dec 31, 2017 4:55 pm
Recently installed Audacity 2.2.1 with Linux Mint. everything works fine until I try to export an audio file (aup), either in MP3 or WAV.
In both cases an error message such as "cannot export to file (wav or mp3)" pops up. Anyone?...
Chaz
Operating System: Linux Debian
Re: Exporting files
Permanent link to this post Posted by steve » Sun Dec 31, 2017 6:04 pm
Chaz wrote:In both cases an error message such as "cannot export to file (wav or mp3)" pops up. Anyone?...
Please give the exact text of the error message (searching for that text in the code brings up nothing).
Re: Exporting files
Permanent link to this post Posted by Chaz » Wed Jan 03, 2018 7:11 pm
The script in the case of exporting to wav is:
"Cannot export audio to/media/chaz/filename.wav"
When trying to export to mp3 : "Unable to open target file for writing"
Thanks, Chaz
Chaz
Re: Exporting files
Permanent link to this post Posted by steve » Thu Jan 04, 2018 9:51 am
Try exporting to "/home/chaz/filename.wav"
The "/media/" folder is usually read only for regular users.
Re: Exporting files [SOLVED]
Permanent link to this post Posted by Chaz » Sat Jan 06, 2018 5:56 pm
OK that worked when I also specified the Music folder, then I was able to save as wav and mp3. Thanks! :D
Chaz
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 2 guests
