how to merge audio regions
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by anothermick » Thu Dec 21, 2017 5:12 pm
thank you in advance for the help.
how do i merge audio regions in the same track?
specifically, i've placed several 7 short .wav files back-to-back on one track, but i want to edit them from this point forward as one unit, not at seven different units.
more specifically still, i want to use the envelope tool to make multiple volume changes across the track as a whole, not to each individual section/region.
thank you.
anothermick
Operating System: GNU/Linux other
Re: how to merge audio regions
Permanent link to this post Posted by steve » Thu Dec 21, 2017 6:13 pm
"Tracks menu > Mix and Render" will mix down all selected tracks into one continuous track.
Permanent link to this post Posted by anothermick » Thu Dec 21, 2017 8:22 pm
thank you!
anothermick
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 3 guests
