"Could not save project. Perhaps $PATH is not writable..."
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by silenteditor » Sun Dec 17, 2017 1:53 pm
Having trouble with Audacity 2.2.1 (and 2.2.0 before it) on Debian.
I have over 200 GB available on the hard drive in question. Standard permissions on my home directory. I open an MP3 file to edit. Choose "Save Project" from the file menu, place the file somewhere in my home directory. I get the following error message in a window:
"Could not save project. Perhaps [the file path in /home/] is not writable or the disk is full."
I am able to continue editing and export the final product as a sound file of whatever format ... but I can't save the project (.aup file).
Any help appreciated. Thanks!
silenteditor
Operating System: Linux Debian
Re: "Could not save project. Perhaps $PATH is not writable..
Permanent link to this post Posted by steve » Sun Dec 17, 2017 2:17 pm
Ensure that you are giving it a legal file name. In particular, don't use the "/" character.
Permanent link to this post Posted by silenteditor » Sun Dec 17, 2017 2:37 pm
Thanks, I did that already (just to be extra sure, I only used ASCII alphabet characters and no spaces.) Same problem persists.
silenteditor
Permanent link to this post Posted by steve » Sun Dec 17, 2017 2:41 pm
I've re-read your first post:
silenteditor wrote:the file path in /home/] is not writable
That's correct. For a standard user account, the file path /home/ is not writable. Your "Home" folder is "/home/username/" where "username" is your log-in name.
Permanent link to this post Posted by silenteditor » Sun Dec 17, 2017 2:46 pm
Sorry for the ambiguity. I was not trying to save in /home/ itself, I was trying to save in a subdirectory of my home directory. I have the normal read and write permissions. Other programs that I run, e.g. a text editor, are able to create and write files in the directory in question.
silenteditor
Permanent link to this post Posted by steve » Sun Dec 17, 2017 2:51 pm
OK, so we will need to get down to the fine detail, because obviously "something" is wrong.
If you shut down and restart Audacity, then generate a 30 second tone (Generate menu), and then try to save the new project as "my-project" in "~/Desktop/", what happens?
Permanent link to this post Posted by silenteditor » Sun Dec 17, 2017 3:01 pm
I followed your steps exactly, and was able to save the .aup file in ~/Desktop without any error.
I did a little further troubleshooting:
First, I exited the program and re-opened my-project.aup, everything worked as expected.
Second, I exited he program again. Restarted the program with a blank/new project. Imported (from the file menu) the original audio file in question, a 107 megabyte MP3 file. I tried to save the resulting project (two tracks, just under two hours) in ~/Desktop as my-project-2 . Got the same error.
silenteditor
Permanent link to this post Posted by steve » Sun Dec 17, 2017 3:55 pm
silenteditor wrote:I have over 200 GB available on the hard drive in question.
How much available space in "~/"?
Permanent link to this post Posted by silenteditor » Sun Dec 17, 2017 3:59 pm
$ df / reports
261999448 used, 222405624 available, 55% used.
$HOME is on the same root partition.
silenteditor
Permanent link to this post Posted by steve » Sun Dec 17, 2017 4:27 pm
Can you try with a different large file to see if the problem is specific to that MP3.
Next
Return to GNU/Linux
Who is online
