Using the envelope tool
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by sciurius » Wed Dec 13, 2017 9:59 pm
Using the envelope tool: creating the first control point almost always causes the envelope to shift since it is very hard to click exactly at the current vertical position of the envelope. Is there a way to create control points without changing the envelope?
sciurius
Re: Using the envelope tool
Permanent link to this post Posted by Trebor » Wed Dec 13, 2017 11:38 pm
sciurius wrote:...Is there a way to create control points without changing the envelope?
Can push envelope points against the +1.0 line ...
push envelope points against +1.gif (317.48 KiB) Viewed 494 times
Trebor
Permanent link to this post Posted by sciurius » Thu Dec 14, 2017 8:45 am
Right...
This will work (I do this) for the "first" control point. But when the envelope is not at 1.0 and I want to add (another) control point, the problem remains.
Peek 2017-12-14 09-43.gif (9.13 KiB) Viewed 480 times
sciurius
Permanent link to this post Posted by steve » Thu Dec 14, 2017 5:44 pm
If you Zoom in vertically on the blue "Envelope" line, that will allow your envelope to be more precise. There are very few cases where the envelope needs to be exact, so long as you can get it close enough that it sounds right.
You would probably find things easier if your waveform was not at such a low level.
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 4 guests
