Rare behaviour with chains
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by jotape1960 » Mon Dec 11, 2017 3:55 pm
I use Audacity 2.2.1 into UbuntuStudio 16.04.3 LTS.
I discovered a rare behaviour with chains, I don't know if it happened before:
When I use some recorded chain (automatic script or batch commands) and I want to edit it and/or rename it... some another recorded chain is erased and lost.
Is it only a local (my installation) issue??? or... Is it a mayor bug???
JUAN
From Chile
jotape1960
Re: Rare behaviour with chains
Permanent link to this post Posted by steve » Mon Dec 11, 2017 5:31 pm
It's not a bug that I'm aware of. Are you able to give step by step instructions for how to reproduce the issue?
Permanent link to this post Posted by jotape1960 » Mon Dec 11, 2017 8:58 pm
Well... Let's say:
1) Create a chain (normalize, filter, equalization..., whatever you want).
2) Save the chain (any name).
3) Create other chains (maybe the same effects, but with difference parameters).
4) Save all the chains you want to create.
5) You can see the list of al the chains you created.
6) Then... click on any chains from the list and edit or rename one of the chains you created before.
When you finish to edit the chain and you save it, then you could see that some other of the created chain, from the list of chains, disappears from the list... and it is lost forever!!!
JUAN
From Chile.
jotape1960
Permanent link to this post Posted by steve » Mon Dec 11, 2017 11:29 pm
jotape1960 wrote:2) Save the chain (any name).
The in is saved when the Chain editor window is closed.
Are you trying to create multiple Chains without closing the editor?
jotape1960 wrote:4) Save all the chains you want to create.
How exactly are you doing that? There isn't a "Save" button (but perhaps it would be less confusing if there was).
Return to GNU/Linux
Who is online
Users browsing this forum: Google [Bot] and 1 guest
