EXPORT OVERDUBBED TRACK ONLY
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by PartTime » Tue Dec 05, 2017 8:55 pm
Hi,
Is it possible to export an overdubbed track only?
PartTime
Re: EXPORT OVERDUBBED TRACK ONLY
Permanent link to this post Posted by steve » Tue Dec 05, 2017 9:00 pm
If you've not mixed the tracks (the overdub is on its own in a separate track), the yes you can:
1) Select the overdub track (click on an empty portion of the info panel on the left end of the track, but take care not to catch the sliders or buttons)
2) File menu > Export Selected Audio (may be in a sub-menu, depending on which version of Audacity).
Permanent link to this post Posted by PartTime » Tue Dec 05, 2017 9:07 pm
Hi Steve,
Thanks for the quick reply!!
That works just as I needed!!
PartTime
Return to GNU/Linux
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
