Chains - some effects - crash Audacity 2.2.0.
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by funk » Mon Nov 06, 2017 8:13 am
Hi,
I have problems with Chains in new Audacity 2.2.0 (Linux Mint 18). If I use chain with effects eg. StereoToMono + Limiter + Export to OGG, everything is OK. Unlike StereoToMono + Distortion (or BassAndTreble, Compressor etc.) + Limiter + Export to OGG, which cause Audacity crash.
Thanks
funk
Operating System: Linux Mint
Re: Chains - some effects - crash Audacity 2.2.0.
Permanent link to this post Posted by steve » Mon Nov 06, 2017 9:31 am
Unfortunately this is a bug that appeared in version 2.2.0 and was not noticed until after release.
A new release is planned for the beginning of December, which is primarily a bug-fix release, and includes a fix for this bug.
If you need to use chains between now and the release of 2.2.1, you could either revert back to Audacity 2.1.3, or build Audacity 2.2.1 alpha from the sourcecode from: https://github.com/audacity/audacity
Permanent link to this post Posted by funk » Mon Nov 06, 2017 9:34 am
Hi Steve, Thanks for reply!
funk
Permanent link to this post Posted by steve » Mon Nov 06, 2017 9:37 am
If you build the alpha version from source, please let us know how you get on with it - user testing allows us to avoid problems like this.
Permanent link to this post Posted by funk » Mon Nov 06, 2017 9:40 am
Sorry, I'm not able to do this :-) I'm a user of Ubuntuhandbook PPA.
funk
Permanent link to this post Posted by steve » Mon Nov 06, 2017 9:41 am
OK, no problem.
Return to GNU/Linux
Who is online
Users browsing this forum: Yahoo [Bot] and 2 guests
