2.2.0 bug
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
2.2.0 bug
Permanent link to this post Posted by mju » Sat Nov 04, 2017 11:57 am
In ver 2.2.0 and previous versions, audacity will crash when I use shift-right arrow to move the cursor while playing.
It only happens when I hold those keys down for quick movement through a large file. Single hits will work normally.
I use linux arch (xfce4).
mju
Operating System: GNU/Linux other
Re: 2.2.0 bug
Permanent link to this post Posted by steve » Sat Nov 04, 2017 12:18 pm
Are you using PulseAudio for playback?
Try selecting the appropriate "hw" option in the device toolbar as the playback device.
Re: 2.2.0 bug
Permanent link to this post Posted by mju » Sun Nov 05, 2017 1:53 pm
I do use pulseaudio. It plays ok. Pressing shift-right arrow works if pressed once, but crashes if I do multiple shift-right too quickly.
mju
Re: 2.2.0 bug
Permanent link to this post Posted by mju » Sun Nov 05, 2017 2:17 pm
additional info:
When run from a terminal I get the error:
audacity: src/hostapi/alsa/pa_linux_alsa.c:3641: PaAlsaStreamComponent_BeginPolling: Assertion `ret == self->nfds' failed.
Aborted (core dumped)
Also, if I change the output stream, I get no audio, but the crash doesn't happen.
mju
Re: 2.2.0 bug
Permanent link to this post Posted by mju » Mon Nov 06, 2017 1:55 pm
Seems to work ok after I installed pulseaudio-alsa plugin.
mju
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: Yahoo [Bot] and 7 guests
