Recording mix (Mic + Computer sound)
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by mamPHP » Mon Oct 30, 2017 1:47 pm
Hi,
We are using Teamspeak and Discord for voicechat in gaming. I'tried all ALSA, PULSE and JACK to record my mic and the chatroom channel voice in Audacity. Is that possible at all?
Regards
mamPHP
Operating System: Linux Debian
Re: Recording mix (Mic + Computer sound)
Permanent link to this post Posted by steve » Wed Nov 01, 2017 1:20 pm
If all of the applications work with Jack, then you could use "Connect" button in QjackCtl to rout sounds wherever you want them to go.
There's some information about QjackCtl here: http://libremusicproduction.com/article ... arted-jack
(Google is your friend)
Permanent link to this post Posted by mamPHP » Thu Nov 02, 2017 11:00 am
steve wrote:If all of the applications work with Jack, then you could use "Connect" button in QjackCtl to rout sounds wherever you want them to go.
I'm honoured to be able to get answer from SiteAdmin or Developer self :) Actually i tried this CLI and Qt tools before, was to complicated and not working with USB mic directly. But i found other way with OBS studio. Just created new scene with Output+USBmic and recording only the PC sound and mic (MOV or MPEG4) without any noise or echo. Almost Perfect then finally edit/export in Audacity!
Thanks again
mamPHP
Return to GNU/Linux
Who is online
Users browsing this forum: Google [Bot] and 4 guests
