metadata for different albums in one recording
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by ingavdh » Mon Oct 30, 2017 8:42 am
hi
audacity 2.0.5 and ubuntu 14.04
how can I edit the metadata for multiple albums recorded in one big recording?
i want to assign an artist for the first 2 hours and a different artist for the second 2 hours, for example.
at the moment i'm exporting all the tracks as Artist 1, deleting half, then exporting them again as Artist 2 and deleting half of them again!
thanks
ingavdh
Re: metadata for different albums in one recording
Permanent link to this post Posted by steve » Mon Oct 30, 2017 8:52 am
The way I'd do it would be include only the metadata that is common to all tracks (if any),, then export all of the files, then use EasyTAG or MP3Tag to tag the files.
Permanent link to this post Posted by ingavdh » Mon Oct 30, 2017 8:56 am
thanks.
so you can only have one metadata thingie per recording?
i'm not an experienced user of audio software (to say the least) so any common sense solutions don't come easily to me :shock:
ingavdh
Permanent link to this post Posted by steve » Mon Oct 30, 2017 4:05 pm
ingavdh wrote:so you can only have one metadata thingie per recording?
One set of metadata per project (a "project" being, everything that's in one Audacity window, which, when "saved", creates one AUP (Audacity Project file) and one "_data" folder).
It would be difficult to manage more than one set of metadata: Imagine if you had two audio tracks in the project, each with its own metadata, and if you then cut and pasted half of one track onto the other, and half of the other track onto the first - what happens to the metadata? Of course, editing can be a lot more complex than that.
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 3 guests
