Audacity wont run [SOLVED]
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by danzi » Sat Oct 21, 2017 4:08 pm
I have installed via apt 2.1.3.0build3-ubuntu16.04.
when I try to run AUDACITY I get this error in terminal:
(Audacity:6189): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
any help would be appreciated!
thanks dan
danzi
Re: Audacity wont run
Permanent link to this post Posted by steve » Sat Oct 21, 2017 4:48 pm
danzi wrote:(Audacity:6189): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
That's just a warning, not a critical failure. I get that warning too, but no reason for it to prevent Audacity from running.
Permanent link to this post Posted by danzi » Sat Oct 21, 2017 6:51 pm
well that's not true fro me.
After the error , terminal goes back to cursor.
However if I run Audacity as SUDO it start but I get ....
"Audacity could not find a place to store temp files, click to select a place"
so I click and
"preference directories' opens
pre selected is "var/tmp/audacity-root"
set ok,
says will now exit, restart to use directory.
I do that and same dialog repeats.
SO I created a new directory
"var/temp/audacity"
which the auto creates
/.audacity-temp
so restart again and no joy.
back to same dialog
so I don't know why this is happening and I don't know why it wont even start unless sudo.
Thanks DAN
danzi
Permanent link to this post Posted by danzi » Sat Oct 21, 2017 10:46 pm
not for me, it does not run at all
DAN
danzi
Permanent link to this post Posted by steve » Sun Oct 22, 2017 12:29 am
danzi wrote:However if I run Audacity as SUDO
Audacity should not be run as sudo.
danzi wrote:.1.3.0build3-ubuntu
What repository is that from?
I'm using Ubuntu 16.04 and Audacity is listed as 2.1.2-1 (https://packages.ubuntu.com/xenial/audacity)
Permanent link to this post Posted by danzi » Sun Oct 22, 2017 10:33 am
Yes I know audacity should not be run as SUDO,
for me that is the only way it will run.
repository is
ppa.launchpad.net/ubuntuhandbook1/audacity/ubuntu xenial
installed version is
2.1.3-0build3-ubuntu16.04
Dan
danzi
Permanent link to this post Posted by steve » Sun Oct 22, 2017 11:05 am
Try removing that version completely, including any user settings ~/.audacity-data and ~/.audacity-files (both are hidden folders, and are created per user).
Then install Audacity from the Ubuntu main 'Universe' repository.
Permanent link to this post Posted by danzi » Sun Oct 22, 2017 1:16 pm
removed audacity
sudo apt-get purge --auto-remove audacity
unchecked repository of audacity
installed via "ubuntu software" GUI
same problem!
will not even start as non-sudo.
starts in sudo.
checked folders/files against my 14.04 machine, and they are the same permssions
when I open in sudo, it ask me to set tmp directory.
So I do set as /var/tmp/.audacity_temp
permissions are owner root, group root.
and it runs ok.
if i change permission of .audacity_temp to owner me, group my-group
it will not run normally OR as sudo.
DAN
danzi
Permanent link to this post Posted by steve » Sun Oct 22, 2017 2:15 pm
danzi wrote:removed audacity
same problem!
Did you forget about ~/.audacity-data and ~/.audacity-files ?
danzi wrote:So I do set as /var/tmp/.audacity_temp
That will not allow Audacity to run correctly, and that is not the correct default location for Audacity's temp folder.
Permanent link to this post Posted by danzi » Sun Oct 22, 2017 3:05 pm
from what I found on inet,
was supposed to remove all including data files.
None the less I will try individual removal of those 2 folders.
As for default tmp folder,
/var/tmp/.audacity_temp is what the program is going to automatically,
so where should the tmp foldr go?
Thaks Dan
danzi
Next
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 4 guests
