Best quality audio format/rate for websites
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Re: Best quality audio format/rate for websites
Permanent link to this post Posted by kozikowski » Fri Oct 20, 2017 5:40 pm
It must be better, it’s more expensive.
16bit does OK. It overloads at 0 and has quiet noise at 96. Most home recordists have a terrible time getting their shows between 3 and as quiet as 60, the AudioBook standard. 16bit easily handles that.
You should be careful not to present in a format nobody can play. 24bit is a studio standard. I don’t think my iPod can play those.
Permanent link to this post Posted by kozikowski » Fri Oct 20, 2017 6:05 pm
There is one more consideration. At home I have a modest internet connection. If I need to download a serious file. I have time to go make coffee. I converted several sound samples from WAV to MP3 so *I* could download them.
Permanent link to this post Posted by briandc » Sun Oct 22, 2017 10:40 am
steve wrote:The ridiculous thing about "high definition audio formats", is that they are perceptively indistinguishable from 16-bit 44.1 kHz.
Got it. Thanks!
brian
briandc
Operating System: Linux Debian
Previous
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
