Keyboard shortcut to apply specific named Equalizer curve?
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by sagetyrtle » Thu Oct 19, 2017 2:30 pm
Is it possible to assign a keyboard shortcut to apply a specific named Equalizer curve?
I was able to create a Chain, but only able to assign a keyboard shortcut to "Apply Chain", then choose the Chain, not the named curve itself.
Thanks for any suggestions or ideas.
sagetyrtle
Re: Keyboard shortcut to apply specific named Equalizer curv
Permanent link to this post Posted by Trebor » Thu Oct 19, 2017 4:35 pm
sagetyrtle wrote:Is it possible to assign a keyboard shortcut to apply a specific named Equalizer curve? ...
You can specify the equalizer-curve used in the chain ...
equalization curve name can be specified in the chain.png (7.76 KiB) Viewed 257 times
You could create multiple chains: each including a different equalizer-curve.
Trebor
Permanent link to this post Posted by sagetyrtle » Fri Oct 20, 2017 3:18 pm
Thanks so much for your answer. Though the Chain is nice, what I'm after is a keyboard shortcut that I can associate with the curve, rather than the Chain (which involves many more keystrokes).
sagetyrtle
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 5 guests
