Audacity device toolbar is empty
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by asravan » Sun Oct 15, 2017 4:40 am
I am using Audacity on Ubuntu 16.04 to record from an electric piano through an input jack. My laptop recognized the recording device and I can see input levels fluctuating when I play from my keyboard (although I can't hear anything). The device toolbar in audacity is empty. When I hit the record button it gives the following message:
"Error opening sound device. Try changing the audio host, recording device and the project sample rate"
I've already tried re-installing my sound drivers. Does anyone know what's going on?
asravan
Re: Audacity device toolbar is empty
Permanent link to this post Posted by steve » Sun Oct 15, 2017 9:07 am
asravan wrote:from an electric piano through an input jack.
What sort of electric piano, and what is the "input jack" that you refer to?
asravan wrote:My laptop recognized the recording device
How does your laptop show that?
What is the recording device?
asravan wrote:I can see input levels fluctuating when I play from my keyboard
Where do you see that?
asravan wrote:Try changing the audio host
What options do you have? In a default Ubuntu set-up there is only one option.
asravan wrote:I've already tried re-installing my sound drivers.
How did you do that?
Permanent link to this post Posted by asravan » Mon Oct 16, 2017 9:39 pm
Electric Piano: Yamaha P45. I'm using a 3.5 mm to 1/4 inch jack
How does your laptop show that? (Fluctuating amplitudes of signal when I press keys on my keyboard)
What is the recording device? (The keyboard)
Where do you see that? (On the Input tab in the sound settings window - Ubuntu 16.04)
Could you please elaborate? I don't quite understand what that means. Thanks.
(Re-installed Alsa)
asravan
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
