How to automatically truncate silence-like parts?
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by vitaly-zdanevich » Sat Sep 16, 2017 8:27 am
Good day to everyone. I use Audacity pretty often - mainly for clearing/adjusting of my recorded lectures. With my last record I faced with a problem that this six hours file has many little silence-like parts. On parts that larger than 100ms I can use `Silence Finder` and manually delete it. But what about smaller parts and that not exactly pure silence? I believe that such parts can be algorithmically identified. Maybe exists some plugin for such task or I can write myself? Thank you for support.
Waveform dB
audacity-silence-like
Waveform dB
vitaly-zdanevich
Re: How to automatically truncate silence-like parts?
Permanent link to this post Posted by Trebor » Sat Sep 16, 2017 4:38 pm
vitaly-zdanevich wrote: I faced with a problem that this six hours file has many little silence-like parts.
aka Skips ... http://manual.audacityteam.org/man/faq_recording_troubleshooting.html#How_can_I_record_without_small_skips_or_duplications.3F
vitaly-zdanevich wrote:Maybe exists some plugin for such task
It's built-in ... Truncate silence
There will probably be clicks where the silences have been removed : you may need a DeClicker plugin.
Trebor
Permanent link to this post Posted by vitaly-zdanevich » Sun Sep 17, 2017 8:06 am
`Truncate Silence` is not an option for such case - because as you can see on the screenshots - this `silence-like` parts in reality a noise-like parts - that is not more quiet than some natural correct silence. Maybe exists some plugin with functionality like inside Noise Reduction - where I can take `profile` (example) and take next actions with such example in mind?
vitaly-zdanevich
Permanent link to this post Posted by Trebor » Sun Sep 17, 2017 1:50 pm
vitaly-zdanevich wrote:`Truncate Silence` is not an option for such case - because as you can see on the screenshots - this `silence-like` parts in reality a noise-like parts ...
"Truncate silence" doesn't just work on true flat-line silence.
You set a threshold on "Truncate silence" : anything below that threshold will be treated as silence.
Before you use "Truncate silence" use "Normalize" to remove the small DC offset you've got ...
flat-line is not on zero = 'DC offset'.png (77.4 KiB) Viewed 489 times
Trebor
Permanent link to this post Posted by vitaly-zdanevich » Sun Sep 24, 2017 7:45 am
Thank you!
I found that normalize with removing of DC offset just increase DC offset, so I search the web about how to fix DC offset and found a solution - High Pass Filter (90Hz, Rolloff: 6dB) that remove low-frequency noise (so as I understand - on my screenshots was not a DC offset but that noise). And after that Truncate Silence - works like a magic. For the last week I lost few hours for manually removing of that silence and after that - manually removing of new clicks using selection in spectral view.
Thank you again!
vitaly-zdanevich
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 4 guests
