auto fit file
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
auto fit file
Permanent link to this post Posted by mc3man » Sun Sep 10, 2017 3:12 pm
In 2.1.x when I open a file it's shown in it's entirety but in 2.2.x it only displays x sec's based on window size.
So for example if the audacity window shows 13 sec then when opening a file only the 1st. 13 sec. are displayed
Is there any way to change this behavior/
Using build from the audacity team ppa so currently 2.2.0-alpha (2.1.2+git20170817+r5628+17
mc3man
Re: auto fit file
Permanent link to this post Posted by kozikowski » Sun Sep 10, 2017 3:51 pm
Control-F (full) does work, right?
Re: auto fit file
Permanent link to this post Posted by mc3man » Sun Sep 10, 2017 4:08 pm
Yep, ctrl+f works. I was just wondering if there was a default setting for this. Anyway no big deal, thanks
mc3man
Re: auto fit file
Permanent link to this post Posted by kozikowski » Sun Sep 10, 2017 4:41 pm
I think it is supposed to do that. The senior elves will be along.
Thanks for the post.
Re: auto fit file
Permanent link to this post Posted by waxcylinder » Sat Sep 23, 2017 4:53 pm
My testing shows that for all the 2.1.x series using File>Open will always open it at the default zoom level, showing 6-7 seconds or so.
Same happens in 2.2.0 Beta and latest alpha.
BUT if you use File> Import to import a pre-existing audio file leike a WAV or MP3 then Audacity fits that to the screen.
So AFAICT there is no change here betwen the way 2.1.x and 2.2.x works :geek:
waxcylinder
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 4 guests
