Display failures in 2.1.3 over 2.1.2
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by Gran Francisco » Tue Sep 05, 2017 10:04 pm
When you put the volume or balance sliders on the audio tracks or playback speed, the indicator (white text on black background) does not appear in 2.1.3. Only a thin black line appears. If you move the slider and you want to know the value, you have to double click and do it from the small window. Is it a program failure? Thank you
Gran Francisco
Re: Display failures in 2.1.3 over 2.1.2
Permanent link to this post Posted by steve » Tue Sep 05, 2017 10:19 pm
Yes it's a bug, and unfortunately no fix yet.
Return to GNU/Linux
Who is online
