Audacity crashes with playback of these files
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by daloonik » Tue Sep 05, 2017 12:07 am
I'm trying to create a backing track with these files:
https://drive.google.com/open?id=0BxrbK ... W1LWEdTZGc
But there is always a problem with Audacity freezing during playback and forcing me to kill the Audacity process.
It's easy to replicate: load all the files and especially you will notice a crackling sound with the drums file. Then play back and pause playback multiple times at various places. Audacity will freeze and become unresponsive immediately after playback.
Also Audacity produces orphan files due to the crash.
I'm running Audacity 2.1.3 on Linux Mint 18.1.
Thanks in advance. this is a very frustrating bug.
daloonik
Operating System: Linux Mint
Re: Audacity crashes with playback of these files
Permanent link to this post Posted by steve » Tue Sep 05, 2017 1:03 am
Try using the "hw" option as the playback device rather than "default" or "pulse".
Permanent link to this post Posted by daloonik » Tue Sep 05, 2017 1:29 am
Thanks for your reply - changing the audio output to "sysdefault" seemed to help a lot! :)
daloonik
Permanent link to this post Posted by steve » Tue Sep 05, 2017 1:38 am
If you still get freezes, try the "hw" option. For example on my computer, the "hw" option is:
HDA Intel PCH: ALC268VC Analog (hw:0,0)
"(hw:0,0)" is usually the default (on-board) sound card.
Return to GNU/Linux and Unix-like
Who is online
