Audacity on Ubuntu - Recording devices issue
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by elresleff » Mon Sep 04, 2017 10:17 pm
I am totally new to Audacity on Ubuntu (16.04 LTS) after using it on Windows for a long time. I am trying to use the record feature through the sound device on my Ubuntu laptop and can't seem to get the right setting. I have been able to do this on my Windows system and I just chalking it up to being a learning curve issue on Ubuntu.
I have the recording device set to Pulse using ALSA - I've also changed it to the HDA Intel PCH: ALC3226 Analog (hw:1,0). All I get is whatever comes through the microphone instead of my sound card. If I mute the microphone, nothing comes through.
This is slightly frustrating, but I know someone has the answer out there. Please... anyone with suggestions is greatly appreciated.
elresleff
Re: Audacity on Ubuntu - Recording devices issue
Permanent link to this post Posted by steve » Mon Sep 04, 2017 10:24 pm
You're trying to record the sounds that are playing on your computer (such as sounds playing in your web browser)?
If so, then set the recording device to "default" in the device toolbar, then click on the recording meter to activate monitoring. Open the system "Sound Settings" (pavucontrol) and in the Recording tab, set Audacity to record from the "Monitor" of the device that you are listening to (If you have only one sound card attached there will only be one "Monitor" option).
Then close the Sound Settings and start recording.
Permanent link to this post Posted by elresleff » Mon Sep 04, 2017 10:57 pm
Success...! Thanks Steve. The REAL problem was I thought I already had pavucontrol installed - I didn't. Got that installed and then got your response which definitely helped right away.
Much Thanks!
elresleff
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
