audacity doesn't start! I need some help...
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by MarPar » Sun Sep 03, 2017 12:18 pm
On my machine (I7 Intel, 16 GB RAM, Nvidia GTX 950) with Xubuntu 16.04 LTS, Audacity this mornig doesn't work and has created a zip debug file (that I allow to this post).
I need help for this. Please read the file zip and contact me.
Thanks and regards.
audacity_dbgrpt-2450-20170903T134803.zip
zip file created by audacity (debug info)
(6.29 KiB) Downloaded 13 times
MarPar
Re: audacity doesn't start! I need some help...
Permanent link to this post Posted by steve » Mon Sep 04, 2017 9:20 am
MarPar wrote:Audacity this mornig doesn't work
When did it last work?
Have you installed any LV2 effects since then? (or any other effects or media software)
Permanent link to this post Posted by MarPar » Mon Sep 04, 2017 9:36 am
I don't remember when I used Audacity, sorry. Have you read the zip debug file that I attached to my first post?
Thanks. I'm very new in Linux and I need assistance for doing things like configuration of the system and of the applications. I'm sure that in this Forum I'll find an answer for playing Audacity soon.
MarPar
Permanent link to this post Posted by steve » Mon Sep 04, 2017 10:03 am
MarPar wrote:Have you read the zip debug file that I attached to my first post?
I'm not an expert with those debug logs, but it suggests to me that a bad LV2 plug-in is interfering with Audacity loading.
I don't know if this will work, but it is a simple thing to try:
Find the file "audacity.cfg" in "~/.audacity-data" (.audacity-data is a hidden folder in your home directory).
Replace that file with this one (this disables plug-in support, except for Nyquist plug-ins, in Audacity).
audacity.cfg.txt
(138 Bytes) Downloaded 12 times
Note that you will need to edit the name of this file from"audacity.cfg.txt" to "audacity.cfg"
Then try to launch Audacity.
Permanent link to this post Posted by MarPar » Mon Sep 04, 2017 10:17 am
I've changed the cfg file as you suggested and restart the pc. After the restart I have launched Audacity but the window of creating the debug report appears. In the attached zip debug file there are the results. It still doesn't work.
audacity_dbgrpt-2555-20170904T121138.zip
debug report
(6.32 KiB) Downloaded 12 times
MarPar
Permanent link to this post Posted by steve » Mon Sep 04, 2017 11:35 am
Could you try launching Audacity from the command line:
1) Open a terminal window
2) Enter the command:
Code: Select all
audacity
Copy and paste the output that appears in the terminal window into your reply.
Permanent link to this post Posted by steve » Mon Sep 04, 2017 11:40 am
Something else for you to try, and I'm quite hopeful that this will fix the problem:
Locate the file:
Code: Select all
/usr/lib/dssi/amsynth_dssi.so
and rename it:
Code: Select all
/usr/lib/dssi/amsynth_dssi.so.bak
Then log out and back in again.
Permanent link to this post Posted by MarPar » Mon Sep 04, 2017 11:54 am
Here we are with le screenshot of the terminal (see attachment)
Audacity in terminal
MarPar
Permanent link to this post Posted by steve » Mon Sep 04, 2017 12:04 pm
MarPar wrote:Here we are with le screenshot of the terminal (see attachment)
OK, thanks. Audacity is crashing too early for that to tell us anything useful.
Please try the suggestion that I posted here: https://forum.audacityteam.org/viewtopi ... 78#p333478
Permanent link to this post Posted by MarPar » Mon Sep 04, 2017 12:50 pm
After renaming the file, log out and log in, I've launched Audacity via CLI:
Code: Select all
[email protected]:~$ audacity
(Audacity:6047): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
no more csLADSPA plugins
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = Connessione rifiutata
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2840
14:46:17: Debug: Unrecognized accel key 'clic sinistro/trascina sinistra', accel string ignored.
14:46:17: Debug: Unknown accel modifier: 'maiusc'
14:46:17: Debug: Unrecognized accel key 'clic sinistro', accel string ignored.
14:46:17: Debug: Unrecognized accel key 'clic destro', accel string ignored.
audacity is open! Success! Thank you very much!
MarPar
Next
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 4 guests
