Switching USB port causes Audacity not-to record and more
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by SickBoy » Sat Sep 02, 2017 2:47 pm
It all started when I bought a hub to go in the old useless floppy hole in my tower which had 4 more usb ports, my motherboard had 6 "midboard" 2.0 ports and the less stuff plugged in the back the better. So, my problem before, which made me boot into windows 7 when I wanted to rip vinyl with Audacity at first seemed kind of resolved, I plugged the turntable in the front, on one of the hubs' port.
So shortly, now I can't get the sound from the turntable come out my PC speakers, and yes I have that thing that is checked by default so that it does so. Secondly, in the past I couldn't record in LInux because the sound was too loud, the 2 green bars to the max, in Windows 7 I was able to easily control, the green bars weren't already dancing way high on idle like in Windows, where only a little bit were showing. And finally, I cannot record, because the sound is too low I guess? But when I press the record button, nothing happens, although it will read a record playing at about -20db, the bars get that far only.
And I know I am using the correct source of sound. What happened there? I even switched it back to the one port I want clear of anything in the back, one of my 2 usb 3.0 ports, and there is no difference at all. I can give you screengrabs if you ask for them, I will glady make them available. At first I though alright, finally I can record in Linux. Not only I can't, before I could, but the sound was like looking at a loudness war album, no dynamics, a big green block (almost) which went way past -6db, they pushed through to the limit. Now if I press record, nothing happens, and the Pause button presses itself down. There was just a bunch of audacious updates and sound updates, no idea if it has a relationship. (I use Mint 17.3). Might make me boot up in Win7 for a while, I decided this was a lazy saturday, I have a infection in a foot, taking antibiotics and very low dose codeine pills for pain, and my cocoon of comfort was broken.
Any help will be deeply appreciated.
SickBoy
Operating System: Linux Mint
Re: Switching USB port causes Audacity not-to record and mor
Permanent link to this post Posted by kozikowski » Sat Sep 02, 2017 4:36 pm
Sorry about your foot.
What happens if you take the hub out?
Permanent link to this post Posted by SickBoy » Sun Sep 03, 2017 6:56 pm
Taking the hub out would mean opening the PC tower and unplug it from the one of the 3 blue port to plug in something to make the 6 midboard usb ports that I can have. It is not an external hub.
SickBoy
Permanent link to this post Posted by kozikowski » Sun Sep 03, 2017 7:01 pm
I didn't think it was. All these problems seem to start when you implanted this internal hub into your system.
Permanent link to this post Posted by SickBoy » Thu Sep 14, 2017 11:49 pm
I'll see...I noticed that mInt 17.3 sees it (the turntable) as (hw2,0) now, even if I plug it to the ports in the back again and reboot.
SickBoy
Permanent link to this post Posted by kozikowski » Fri Sep 15, 2017 10:36 pm
Your machine seems to have scrambled USB port management. USB management isn't any too good when everything is working perfectly, if you have internal, user-installed hub hardware and the system doesn't know how to deal with it, I bet you're going to get what you got.
Take the internal hub out.
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 3 guests
