Import RAW-File with sample rate > 100_000
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by Luk4s » Wed Aug 30, 2017 2:35 pm
Hello,
why is the sample rate limited to 100000 at Raw-Data imports?
See: https://github.com/audacity/audacity/blob/c11e3d1511dbb3d25aa54ae40d0dd5171a1c23a2/src/import/ImportRaw.cpp#L493
Is this just a check to prevent wrong user input or is the import method unable to handle sample rates over 100kHz?
Best regards
Lukas
Luk4s
Operating System: GNU/Linux other
Re: Import RAW-File with sample rate > 100_000
Permanent link to this post Posted by steve » Wed Aug 30, 2017 3:22 pm
I'd guess that it's just a semi-arbitrary sanity check. In rare cases where you want to import RAW data at a higher sample rate, you can use the track drop-down menu to set the sample rate (http://manual.audacityteam.org/man/audi ... _menu.html) up to 1,000,000 Hz
Permanent link to this post Posted by Luk4s » Wed Aug 30, 2017 6:45 pm
Thank you for your fast answer!
Your suggestion was my previous workflow.
Since it's only a raw case, i simply forked the project and customised the default values to my needs.
Luk4s
Permanent link to this post Posted by steve » Wed Aug 30, 2017 8:47 pm
Luk4s wrote:Since it's only a raw case, i simply forked the project and customised the default values to my needs.
and no problem over 100,000 Hz I presume?
Out of interest, why do you need > 100 kHz RAW PCM?
Permanent link to this post Posted by Luk4s » Thu Aug 31, 2017 4:18 pm
No problems so far.
I use audacity to view acoustic emission recordings, it's a nice tool to get a first overview.
Luk4s
Permanent link to this post Posted by steve » Thu Aug 31, 2017 5:03 pm
Luk4s wrote:I use audacity to view acoustic emission recordings, it's a nice tool to get a first overview.
It's amazing some of the things that Audacity is used for - this goes onto my mental list of more unusual uses ;)
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
