16.04 Remove human voice from song in 2.1.3
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by meetdilip » Tue Aug 29, 2017 1:02 am
I have a music file (.opus) from which I want to remove human voice ( deep, male ). Is there any preset tool available ? I tried
Effects > Plug-in 1-15 > Voice Reduction and Isolation.
Also tried
Effects > Plug-in 16-17 > Vocal Remover
Both didn't work as expected. No human voice cancellation at all with default values.
meetdilip
Re: 16.04 Remove human voice from song in 2.1.3
Permanent link to this post Posted by kozikowski » Tue Aug 29, 2017 2:44 am
Is it a mono sound file? One blue wave? If it is, that's the end of the story. Vocal Cancellation works by pitting the left and right sound in a stereo show against each other. It stops dead if there is no stereo show. And even if there is, most of the tools fail if the voice isn't in the exact left-right middle of the performance. If the performer wanders (stage performance) or spends their time off-center, that can be deadly.
Now suppose the performer is in the middle and was intentionally mixed that way, but somebody added "deep" stereo echo and effects to the voice. The voice goes but the echoes remain.
Second verse:
http://kozco.com/tech/audacity/clips/MysteryTrain3.mp3
Anything else in the middle of the song usually goes, too, such as bass and drums.
Vocal Removal fails many more times than it works.
Permanent link to this post Posted by meetdilip » Tue Aug 29, 2017 3:03 am
Thanks for the reply. There are 2 set of graph when viewed in Audacity
Also, it says Stereo , 48,000 Hz, 32-bit float
meetdilip
Permanent link to this post Posted by kozikowski » Tue Aug 29, 2017 3:22 am
Then I'm out. It's possible to have a stereo voice track so damaged that even though it satisfies all the rules, it still won't work.
Can you select about 10 seconds of mostly voice and post it here? The less accompaniment the better.
viewtopic.php?f=49&t=72887
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 5 guests
