Linux Mint 18 KDE Audacity displays wrong extension on save
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by tesquincrydd » Mon Aug 28, 2017 4:31 pm
This has been pretty consistently the case for the last few versions/dot-upgrades of the app.
I have MP3 set in my prefs, but the app always ends the filename of the file I was editing as ".aiff."
Is there any way to change this?
Crydd
tesquincrydd
Operating System: Linux Mint
Re: Linux Mint 18 KDE Audacity displays wrong extension on s
Permanent link to this post Posted by steve » Mon Aug 28, 2017 5:46 pm
You mean that Audacity gives the default wrong extension on Export ("Save" is for saving Projects, not audio files).
Yes that is correct - it's a bug. I believe that it has been at least "mostly" fixed in the up and coming Audacity 2.2.0 version (I'm not sure off hand if it is completely fixed - please raise the issue again if you find the problem in 2.2.0 when it becomes available).
Return to GNU/Linux
Who is online
Users browsing this forum: Google [Bot] and 2 guests
